Question about Fish
Fluval My fluval fx6 has primed but won't work ?
Light switch stopped working on fluval chi
The switch may have failed and will have to be replaced.
Oct 15, 2014 | Hagen Fluval Chi 5 Gallon Aquarium
How to stop fluval accent filter bubbles
How do u get the filter water to come down to the bucket?
Dec 06, 2013 | Fluval Fish
No bubbles from fluval q1
can't get airpod air pump to blow bubbles
Mar 27, 2013 | Hagen Fluval Q1 Aquarium Air Pump
Fluval chi aquarium light does not turn off, defective switch how do I repair it?
Much too late to help, I'm sure, but the cheapest fix would likely be to add a simple tap switch.When the tap switch is turned off, it cuts the power off and the light will go out. A tap switch is simply an outlet with a switch fitted. Plug the tap switch into the wall, plug the aquarium light into the tap switch and you're set. They're cheap at places like Home Depot, likely half the price of the replacement switch from Hagen, who makes Fluval. Also a great way to make it easy to turn filters on and off without having to pull the cord from the outlet.
Mar 09, 2013 | Fish
How to fix fluval led
on this tank the lights are built into the filter pump housing , if they go bad it might be possible to retrofit a new sealed light bar into the same space , but you will need to have previous knowledge of electronics and specify L.E.D. lights as they don't work like regular light bulbs but require a special kind of power or will be damaged if hooked to wrong type of power I suppose its possible to use batterys but id have no idea how long that would work
Jan 29, 2013 | Fluval LED Edge Aquarium 6-Gallon Aquarium...
Can someone help me with my fluval chi?
I did some research on the internet for this Fluval Chi-- I see that it is a 50 watt unit-- and others have had some problems with water circulation--- In other words, the pump is not moving enough water--
Could that be a clue?-- What other clues can you give to us to help you further?
Mack B
Jan 10, 2011 | Vacuums
2004 FZ6 Fazer: oil for a 2004 fx6?...
The recommended engine oil for the Yamaha FZ6 is as follows: SAE 10W30, SAE 10W40, SAE 15W40, SAE20W40, or SAE 20W50. The exact weight will depend on the average temperatures the motorcycle will be exposed to.
Any oil you use must meet the following standards: API service SG type or higher, JASO standard MA.
Be sure you buy an oil that DOES NOT have friction modifiers for increased fuel economy. These are NOT for use with a "wet" clutch, such as those found on motorcycles.
May 17, 2010 | 2004 Yamaha FZ6 Fazer
Fish Logo
85 people viewed this question
Top Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Fish Expert? Answer questions, earn points and help others
