Question about Oregon Scientific Radio Communications
Freetalker rd-008B set repeater station
Can't change the channel or set the repeater channel on this. I follow instructions and it never gives me the options.
4 Suggested Answers
SOURCE: Toshiba ER-684 microwave time setting?
clock - clear - enter time - clock
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to TV..you then can watch and record 2 separate channels.
Posted on Mar 01, 2010
muntejaya
  • 10421 Answers
SOURCE: Give Me a canon printer driver ip1800 free download
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay plad
Posted on Feb 12, 2011
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
How can we preset radio stations on RD-N1
I'm not familiar with this particular stereo but typically radio presets are programmed by manually seeking out your favorite channel. Once you' be tuned in, press and hold the button (usually numbered 1-5 or 1-6 for preset programming) hold the button until you hear a beep or the display flashes briefly. If this is a newer touch screen style radio, these instructions may be antiquated and most likely insulting :)
May 30, 2014 | JVC RD-N1 Micro System with CD Clock Radio...
FRS 2Way Radio 14 Channel Conair Expedition MODEL FRS200SLV MANUAL
Here is some information that might help.
Range can vary due to topographical and atmospheric conditions. Voice transmissions on some channels are not permitted by law.
Use in DUPLEX mode, Repeater stations can re-transmit your signal over a wider area giving you extended range depending on the location, height and availability of the local repeater station.
For information on the locations of repeater sites in your area visit the manufactures website or look-up UHF channels and frequencies for your area.
Note: some channels / Frequency's are to be Avoided.
UHF Repeater operation is used when long distance communication is required, unless specifically needed use of the repeater channels is to be avoided. Some channels and emergency channels, some are calling channels for establishing communication and some are customary road vehicle channels.
You will need to look these channels up for your Area.
Other stuff on this subject on safety and safe operation.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off your radio in any location where posted notices instruct you to do so such as healthcaer facilities.
Feb 06, 2014 | Radio Communications
Hi, was just wondering how to enter a security code after the battery has been recharged? It is for a Blaupunkt Verona CR43 [1994]. I have the 4 number code, but don't know how to enter.
Blaupunkt Verona CR-43 Code Entry Instructions
Turn on the radio, the display will show 'COD'
Press preset [ 1 ] repeatedly for the first digit followed by [ station + ]
Press preset [ 2 ] repeatedly for the second digit followed by [ station + ]
Press preset [ 3 ] repeatedly for the third digit followed by [ station + ]
Press preset [ 4 ] repeatedly for the fourth digit followed by [ station + ]
Finally press the [ station + ] button to save.
Feb 10, 2011 | Car Audio & Video
Need code to program universal remote
All you have to do is follow all the steps to enter the code and when you get to the point of entering the code (DONT) just press the channel up button repeatedly but at a slow pace the remote will eventually change the channel on your tv (Tv has to be on) when it changes (STOP) and press the enter/ok, or similar button and that will lock in the code and vwalla you dont have to get up and change the station again.and if it messes up again the follow the same steps and it will fix it again.Good Luck too you.If you follow the instructions this will take you through all the tv codes that the remote has stored and eventually the code for your tv.
Jan 02, 2011 | RCA TruFlat 27F520T 27" TV
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Manual and battery charger needed
I'm still looking for the manual (?).. it's more of a pamplet as I recall.
The battery charger is...
AC/DC Adapter Model 0750200DF
Specs are:
120 V AC 60 Hz to 7.5 /v 200ma
If you can't find the right adapter, you can probably get one of the universal adapters that will work.
I also recommend that you replace the batteries with "Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
for getting."
Much more talk time than the original batteries.
Dec 07, 2007 | Columbia Telecommunications Group FRS 22...
Radio Communications Logo
49 people viewed this question
Top Oregon Scientific Radio Communications Experts
eradiostore
eradiostore
Are you an Oregon Scientific Radio Communication Expert? Answer questions, earn points and help others
