Question about Humminbird 561 Fishfinder
Need to reset factory settings
It only read speed and water temp
Mariva 1.4. Why does temperature gauge reading fluctuate?
check grill and radiator fins are not plugged and fan is not damaged and is working.
sounds like a thermostat or water pump issue.
Jan 09, 2016 | Vauxhall Cars & Trucks
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
My 2002 Dodge stratus is running cold when on the Highway, and hot at a stop light. Temp is going up and down too much. It is also randomly jumping at different times. High speed and low speed the jump...
I would suggest having the engine temperature sensor and circuit checked, as well as your engine temperature guage. The guage is best checked with the use of a scan tool used by the dealer or a repair facility. If no signs of actual malfunction of the vehicle are present, you may just be throwing money at the car because of a false reading on your temperature guage. Some cooling systems require a specific filling procedure. If not done properly, air will be trapped in the system, causing similar issues to what you are experiencing. That would also cause loss of heat in the cabin, as well as overheating of the engine.
Oct 07, 2012 | Dodge Cars & Trucks
2004 Impala ls temperature dash gauge
fans came late on those car,like 212 and second fan comes on at 224,you reprogram it to come a lot sooner,,other thing is there might be gunk inside the block,and coolant has hard time to pass through,and staying longer than enough in block temp goes high,even tough the radiator is doing it's job,it is just coming out block lot hotter than it suppose to be,and gauge read the block not the radiator
Apr 18, 2017 | 2004 Chevrolet Impala
Jandy lx250 won't keep water hot
what size pump motor slow the water down put a bypass in
Feb 27, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Gauge reads Hot but truck doesn't appear to be overheating - help
is antifreeze dirty looking and if was changed was it chemically flushed?
Jul 06, 2009 | 2002 Nissan Frontier Crew Cab
2002 LIBERTY OVERHEATING:
do you have a "check engine" light on? A bad temp sensor would give a wrong reading. Do you get heat from your heater core? Also make sure you are getting a good flow from catalytic converter and muffler so you know they aren't plugged heating up engine temp. Also make sure all your heat shields are in tact. Are you using 50/50 mix or mostly water? Though in cold temps you normally want to use more antifreeze less water, I would try more water, less antifrezze.
Mar 11, 2009 | 2002 Jeep Liberty
Humminbird 561 Fishfinder Logo
55 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
