Question about SBU-EL Great Quality Heavy-duty Atv Cover Quad 4 Wheeler Fits Honda Fourtrax
Change stator how to change stator?
1988 Kawasaki 750 Vulcan change the stator
Hi, Dan this is your lucky day should take you about 1 hour to change a stator for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
stator replacement walkthrough
Kawasaki Vulcan VN750 stator replacement without removing the engine
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki/kawasaki-vulcan-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 23, 2017 | 1988 kawasaki VN 750 Vulcan
I have an 07 yamaha r6 and having troubles keeping it running. I bought a new battery, changed the Rectifier, and changed the stator twice! Now the stator is out again and I have no clue in why it keeps...
has your battery got the correct amp hour rating for the bike.sounds like the stator is getting too hot,check all earth conections and again the rectifier and its conections closley.
Nov 17, 2014 | Motorcycles
Changing stator on 2009 xl1200
In order to change the stator you need to drain the primary fluid , remove the cover. And remove the primary chain, clutch and compensator assembly. Then you need to remove the rotor. Behind that is the stator.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_5bac37c3cb991fdb
Dec 02, 2013 | Motorcycles
Change a stator on revtek 100
Hi Anonymous, for more information on your question please visit the websites below and good luck:
Stator Repair 1 of 9 Removing Inspection Cover on Outer Primary Cover
Jun 22, 2012 | 2003 Harley Davidson FXD Dyna Super Glide
Stator change
main engine heat sing up side have 4 bolt.open it clearance pocket inside.
May 30, 2012 | 1992 kawasaki VN 750 Vulcan
I changed my stator on 2002 yz 250 after it stop running ..so with new stator the bike lasted about 4 laps at track .i bought aftermarket stator .do you think i just got bad stator or is something else...
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Stator Failure
Ignition Stator Symptoms
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 25, 2012 | 2003 Yamaha YZ 250
Replaced voltage regulator,still not charging
check output of stator unplug should get raw volts 40 volts or higher just check w/ vom. don;t run to long w/ stator unplugged .. smell primary funny smell possible burnt stator..often when ill change reg ill just change stator 2 .. good luck,,
Sep 18, 2011 | Harley Davidson FLHT Electra Glide...
How do i change the altenator
The alternator on your bike is not external. What you will probably end up changing is the rotor if the magnets are bad, or the stator, or both. The stator is the stationary piece that the magnets circle. The set up can either be a rotor centered within a stator or a rotor that looks like a flywheel with the stator under it. In either case, you will need to perform some disassembly and I would recommend you get hold of a service manual to ensure it's done correctly. I would also recommend that you troubleshoot the electrical system extensively (fuses, continuity, grounds, connectors) before assuming the alternator is bad.
Jun 23, 2011 | kawasaki ST 502 Motorcycles
I have an oil leak from where the stator wires come out of the primary cover. Is there a way other than changing the whole stator to fix it?
you have some seals that are leaking from around the crankshaft the stator is supposed to be sealed from the oil you wont have to change the stator just the crank seal
Feb 20, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
SBU-EL Great Quality Heavy-duty Atv Cover Quad 4 Wheeler Fits Honda Fourtrax Logo
234 people viewed this question
Top SBU-EL Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a SBU-EL Health and Beauty Expert? Answer questions, earn points and help others
