Question about Stanley Bostitch 02210 Electric Stapler w/Anti-Jam Mechanism- 20 S
Doesn't staple but have power and staples
I guess "electric eye" isn't working. Is it repairable? How?
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
  • 384 Answers
SOURCE: stanley bostitch electric staple 02210 won't
You must have bought the Southern model. We work at a little slower pace here.
Posted on Sep 09, 2009
SOURCE: can't load staples
You must use the Arrow T50 staples. I tried to no avail using the T20 size staples and was ready to pull my hair out! Once I used the T50 staples, it was a breeze. I have had no issues loading staples since then.
Posted on Sep 19, 2009
  • 342 Answers
SOURCE: Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Posted on Apr 05, 2010
  • 34 Answers
SOURCE: I have a very old Bostitch staple gun Model T5.
You should not need any tools to lift the guard/nose piece. The T5 nose piece cleary has engraved on it "Pull Up To Insert Staples". To remove old staples, use a pencil or similar rod to depress the hammer/striker above the staples while the nose is open.
Posted on Aug 07, 2010
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Aug 09, 2014 | Staples Swingline® 36115 Staple Guns Tools...
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
How do I add more staples to a Panasonic Electric AS-302N stapler
I have one right here. Push the button in the back (above where the power cord enters the machine.) The tray holding the strips of staples should pop out of the front of the machine. If it doesn't, try grasping under the staple tray and gently pull the tray out while pushing the button in back.
The button is a release button, while the tray is spring loaded to pop out..
Jul 14, 2011 | Tools & Hardware - Others
How do you load staples in ET501? I pinch the back of the loader together but it won't pull out.
Try pinching it and pushing it down at the same time. If that doesn't work then there is likely a jam.
Jul 02, 2011 | Heavy Duty Arrow Et501 Electric...
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
Arrow Fastener Co./Electric Staple Gun - ETF50BN
First make sure no staple is jammed between the hammer and the anvil or plunger and you might also try to spay with pb blaster or wd 40 and pull yhe trigger several times very rapidly and see if this will free plunger , does work to free sometimes
Jan 22, 2009 | Arrow T50P ARROW STAPLE GUN
Stapler repair
Sydney 02 8004 2111 you might have to post to sydney for service
Nov 15, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
Stanley Bostitch 02210 Electric Stapler w/Anti-Jam Mechanism- 20 S Logo
156 people viewed this question
Top Stanley Office Equipment & Supplies Experts
k24674
ray gallant
Tom Chichester
Are you a Stanley Office Equipment and Supply Expert? Answer questions, earn points and help others
