Question about Intel Computers & Internet
Cannot install camera cu98a on windows 8
It works on windows 7 but not 8
I purchased a HXSJ Webcam 480P HD Web Cam. OS is Windows 7-won't work. Successfully installed software.The device manager says it's working--no camera or sound. Is my OP system too old (Windows 7 pro)
No! Actually Windows 7 Pro is VERY stable and a REAL workhorse AND performer!... Who needs a pig 8 or 10 that STILL is not working right?!
Ahough your HXSJ camera appears to be a nice one, it's only 480p ~ and there is not much "HD" to that! I would NEVERtrade my working Windows 7 Pro to get any 480p camera working!
Instead, cameras are SO reasonable today... get one that IS 'plug and play' and is compatible with Win 7!
Shucks, check out this AMAZING camera:
"USB 50MP HD Webcam Web Cam Camera for Computer PC Laptop" For under $5 SHIPPED!
eBay:
162334052723
{Maximum static pixel: 50.0M pixels (2560x1920, 2848x2800, 3648x2736, 4000x3000, 6000x8000) (with software boost/ upscaling)}
Anthony
Apr 04, 2018 | Computers & Internet
Is there a driver available for Windos 10?
This is a relatively old device. Creative no longer supports it. On their website, the last driver update was in Sept. 2007. This provided support for Windows VISTA. Now, VISTA drivers often worked under Windows 7. Some even worked under Windows 8. I am providing the link to the driver download so you can try it if you wish. You may be able to get it to load using Windows VISTA or Windows 7 compatibility mode if it won't install directly under Windows 10.
http://support.creative.com/downloads/welcome.aspx?nDriverType=1#type_1
Dec 20, 2015 | Creative Live Cam Notebook Pro Vf0250 Web...
I have Medion akoya e7214 laptop and i just installed windows 8 on it,now the cam isn't working,I rang up the Medion support,and they told me that they don't support windows and that i need to buy a new...
Try and find out what the manufacturer and model of the camera is and search the manufacturer's site or the internet for Windows 8 drivers. There is not much else you can do. The notebook was designed for Windows 7 and there are not very many Windows 8 hardware device drivers available.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Nov 22, 2014 | Medion Computers & Internet
Skype certifield
I have OS Windows 8. Installed Skype. Installed drivers for Windows 7. Camera works fine on Windows, but not skpe. Any suggestions?
Sep 17, 2013 | Microsoft LifeCam VX-3000 Web Camera
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
Asus 53 n laptop
1. option - Removing Windows 8 by installing Windows 7 over it*:
Go to the disc where you have the Windows 7 installer.
Then right click, click on Mount, when done, click on the Setup file and install Windows 7 over your current system.
2. option - Keeping Windows 8 and installing Windows 7 alongside it**:
Restart the Windows 8 system, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 .iso file on.
3. option - Running it from a DVD, but keeping/removing*** Windows 8:
a) go to the disc where you have the Windows 7 .iso file installer.
b) move the .iso file to a easily accessible place like Desktop.
c) then right click on the .iso file and click on Burn disk image, choose the DVD you want to boot from ( You need a readable DVD), and then check the checkbox which says " Verify disc after burning ".
d) click on Burn.
e) when that is done, close all open programs or/and windows and restart your computer, before Windows logo shows up, keep pressing F12, then choose the disc you have Windows 7 installer on.
Note - please read everything carefully. I suggest you to use the 3. method.
* - when in the setup, you have no option to go back to Windows 8.
** - this step might not work, because not all computers support that.
*** - you can choose to either create a new partition on which you will install Windows 7 or install it over Windows 8 by either kepping or not keeping your personal files.
Please reply to this solution: did it help you or not and what improvements in my solutions do you want, and rate my solution from 0-5.
Jan 12, 2013 | Computers & Internet
Will software for windows 7 work on windows 8
Yes most software and hardware that worked with Windows 7 will work with Windows 8, I would just install it and see if it works.
Dec 30, 2012 | Video Cameras
Install driver canyon web camera f/2.0 f:4.8mm
Drivers could be installed for older Windows versions. When you camera is from the time before Windows 7, for that check the box it came in, you ran out of luck. Since Windows7 Microsoft only allowes certified drivers in their OS. The drivers you still have for older versions, you can't get them in windows 7 or 8. You always could try a generic driver, but if you webcam has special functions, they most likely won't work on newer OSn.
May 23, 2011 | Computers & Internet
Canon PowerShot S3 IS & Windows 7
This is correct. The S3 is discovered by windows 7 and will allow download of pictures by Windows Picture download. The Canon Utilities software - Zoombrowser - will not work with windows 7 as the software cannot detect the Camera via Windows 7.. Also, Camera window will not start, if using the PC/laptop for remote image recording. If you virtualise XP within Windows 7 this still will not work. The only solution at the moment, if you are deperate, like I was (as I use the Remote Capture process a lot), is to either stick with Win Xp or Dual boot XP on a smaller partition.
Jan 04, 2010 | Canon PowerShot S3 IS Digital Camera
I can't get the driver software to work on my computer and it won't recognize the camera. I'm runnning a newer HP laptop top with Windows 7.
Older versions of Kojak's EasyShare software do not support the Windows 7 operating system, but Kodak's new version 8 does. You probably just need to download/install the new software at www.kodak.com
Dec 31, 2009 | Kodak EasyShare C913 Digital Camera
Computers & Internet Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
