Question about Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch
Need A Manual for the LeRoch with the green rubber wrist band. Can not set the time or date. Tried holding down the restset button. only changes 24 to 12 or vice a versa
My father in law has an old Casio model 548 wrist watch. It's stuck in military time and he wants to reset the time to a 12 hour option and move into daylight savings time. Can you help?
from the user manual press the button closest to the seconds display on watch . bottom right button in normal time display to switch between am / pm time or 24 hundred military time.
http://mygshock.com/casio-manual/548/
enlarge the internet browser display to read which button to press to change the time or date.
press button B top left button to go into change mode
press button C bottom left button to move to seconds or minutes or hours .
press button A bottom right button to advance the time
press button b top left button to go back to normal time display
Jun 01, 2018 | Casio Watches
How do you set the time/date, etc.? This watch is a 1440 sports with plastic wrist band.
press and hold mode button until the digits flash (it is to set the alarm) then press again once the mode button, this time the time flash to be set, the digit that flash is changeable, the lower right button is for adjusting, the upper right button is to choose what you are going to change, while pressing the upper right button you will see all you have to change the time , the date, the day of the week. if your done with all of this. press mode button once, i hope i had been helped you.
Sep 06, 2011 | Timex 1440 Nylon watch
My Sportek Watch (Alarm Chronograph Water Resist 30 m, with velcro band).... I can't reset it...lost manual
you may find a manual from the manufacture. hold the mode button down 3-5 sec's. the hr should blink ,use the opposite side buttons to change the number, then press mode again mins blink change, do this and set hr,min,sec, am or pm? then date month,day yr. press final time and time should be shown with no blinking. you can also hold in all buttons and let beep 5 times it resets to zero defalt settings
Jun 17, 2011 | Watches
How do you set the time on an Armitron 165 wrist-watch?
Hi wtgillo,
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
  • After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Have a nice day,
mvincentc
Apr 21, 2011 | Armitron Watches
How do I change 24 hour time to 12 hour
You have to press the ADJUST button then you hold down the MODE button and while you are holding down the MODE button press the G (illuminator button)
Jan 27, 2011 | Casio G-Shock Classic DW6900-1V Wrist...
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
How do I set the time for nike imara fit WR0076-002 wrist watch?
How to set time(hour minutes)/date(day, month, year)/power hour on nike imara fit:
PLEASE READ CAREFULLY
STEP 1:
First hold the button for set/light.
STEP 2:
wait for the "hold to set" message to appear
once it appears, keep on holding the button until the hour is ready to be set or when the hour blinks.
TIP: Pressing the mode will enable you to choose from setting (HOUR, MINUTE, DAY, MONTH,YEAR, 12/24 HOUR FORMAT, POWER HOUR.)
STEP 3:
To set HOUR: press the start(for higher values) or stop (for lower values) button, choose whatever hour you want to set the time.
*If you are done setting the time press the set/light button, and there you have it.
If you still need to change the minutes of your digital watch proceed to step four.
STEP 4:
After, you have undergone step 1, & 2, or step 1, 2, & 3 (either way it'll still work), press the mode button and then, minute is ready to be set or when the minute blinks.
To set MINUTE:
press the start (for higher values) or stop (for lower values) button, and choose whatever minute you want to set the time.
*If you are done setting the minute, press the set/light button, and there you have it.
If you still need to change the date specifically, the day of your watch proceed to step five.
STEP 5:
To set date, specifically, DAY:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode twice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode once.
To set DAY: press the start (for higher values) or stop (for lower values) button, and choose whatever day you want to set the date.
*If you are done setting the day, press the set/light button, and there you have it.
If you still need to change the date specifically, the month of your watch proceed to step six.
STEP 6:
To set date, specifically MONTH:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode thrice. If you have undergone step 1, 2 , 3, & 4 you need to press the mode twice. If you did it step by step until 6, press the mode once.
To set MONTH:
press the start (for higher values) or stop (for lower values) button, and choose whatever month you want to set the date.
*If you are done setting the month, press the set/light button, and there you have it.
If you still need to change the date specifically, the year of your watch proceed to step seven.
STEP 7:
To set date, specifically YEAR:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode four times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode thrice. If you skipped step 6, press the mode twice. If you did it step by step until 7, press the mode once.
To set YEAR: press the start (for higher values) or stop (for lower values) button, and choose whatever year you want to set the date.
*If you are done setting the year, press the set/light button, and there you have it.
If you still need to change the 12/24 hour format of your watch proceed to step eight.
STEP 8:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode five times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 4 times. If you skipped step 6 & 7, press the mode thrice. If you skipped step 7, press mode twice. If you did it step by step until 8, press the mode once.
To set 12/24 HOUR FORMAT: press the start (for higher values) or stop (for lower values) button, and choose whatever format you want to set the time.
*If you are done setting the 12/24 hour format , press the set/light button, and there you have it.
If you still need to change the power hour of your watch proceed to step nine.
STEP 9:
*If you have only undergone step 1 & 2, or 1, 2, & 3, you need to press the mode six times. If you have undergone step 1, 2 , 3, & 4 you need to press the mode 5 times. If you skipped step 6, 7, & 8, press the mode 4 times. If you skipped step 7 & 8, press mode thrice. If you skipped step 8, press mode twice. If you did it step by step until 9, press the mode once.
To set POWER HOUR: press start for 3, 6, 12, 24 to set the power hour.
Press set/light to set POWER HOUR.
Mar 26, 2009 | Nike Imara Fit WR0076-002 Wrist Watch
Watch instructions
I had the same problem!!!!!!!!!!!!!!!
but i finally found out how!!!!!!!!!
All you have to do hold the "reset" button for about 10 secs. Then one-by-one the time, date, and seconds will and use the "ST/STP" button to change it. Then, you have everything set right, hit the "reset" button and that will finalize it.
Jun 04, 2008 | Watches
Stting the time
http://assets.timex.com/instructions/w3Instr.pdf
Try the link above for a manual.  It is NOT the same watch, but does have some buttons named similarly to the 1440.  Go to the Time and Date section.  The key was to hold down the SET button till the seconds flashes, then use START/SPLIT to adjust the value and MODE to toggle to the next field etc.
Best of luck
May 29, 2007 | Timex 1440 Sports Quotient¿ 53612...
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch Logo
372 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
