Question about Corby Trouser Press 7700
Corby trouser press
Dismantle repair heater
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Eurolab steam press is switching on but stays cold. Even on highest setting.
Not an answer, but a note to say this same thing has just happened with mine in Sydney. Its only three months old. I have contacted Deals Direct, and they don't have any repair options. They won't replace it becuase they model they have in stock is a newer one to the one I have, so a return seems to be the only option. Pity, because I loved this thing. It really made ironing easier.
Apr 15, 2015 | Garment Steamers & Presses
Eurosteam iron no power
try it in another power point , otherwise have it repaired at a service center . not suitable for home repair.
Nov 13, 2014 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Parts
Almost any service center could get you one
Oct 14, 2014 | Singer csp-1 magic steam press
Elna ironing press manual
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Jul 12, 2014 | Garment Steamers & Presses
Heating pad is wrinkled so clothes come out wrinkled
I thought my old one was faulty so I bought a new one and still experience the same wrinkling problem!
Dec 22, 2013 | Corby Trouser Press 7700
I have a Corby 7700 pants press that does not press the pants
Here are the instructions for this product:
http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions
Feb 14, 2013 | Corby Trouser Press 7700
Corby 7700 will not heat up enough to press pants
Here are the operating instructions for this product: http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions#Operating_Instructions
Corby Trouser Press 7700 Logo
110 people viewed this question
Top Corby Garment Steamers & Presses Experts
Tom Chichester
ray gallant
Are you a Corby Garment Steamer and Press Expert? Answer questions, earn points and help others
