Question about Yamaha P90 Digital Piano
Connect speakers to yamaha P90
How do I connect boston speakers to P90
Yamaha p90 keyboard sounds deteriorating
Does this still happen while using headphones? If so, I would suggest trying a different power adapter. If it's clean through the headphones then you may have a speaker malfunction.
Nov 03, 2016 | Yamaha Music
P90 sustain sound won't stop some times when am playing
You could have-
dirty contacts on the switch inside the pedal
dirty contacts in the jack the pedal cable plugs into
a cold/loose solder joint where the cable connects to the plug or to the switch.
If you rule those all out it's an internal problem with the pedal, which you can check by using another pedal, or it's internal to the P90, which will need to go to the shop.
Feb 25, 2015 | Yamaha Music
Check and see if there is a switch on the foot pedal. Check the P-90 menu under footswitch to make sure it is set to sustain.
Yamaha emx 88s
amplifier module faulty, it may even damage your speakers if it had dc on the speaker terminals. have a qualified technician to check and confirm all components.
Dec 11, 2014 | Yamaha Music
Hello, I have a Yamaha P90. 4 keys are not responding. all others are ok and give sound. What happened ?
If they are the same note- different octave- it may be a bad solder joint near the main oscillator IC.
If they are the same cluster (adjacent white keys or adjacent black keys) in the octave, it may be a faulty wire connection.
Apr 01, 2012 | Yamaha P90 Digital Piano
I have a hardly used Yamaha p90. I get very little sound from the speakers esp. the left one. I sprayed the volume switch with de-ox-it? as suggested but now have no sound at all. I took the case and...
NEVER use de-oxit in a volume control potentiometer !!! Use it ONLY on metal switch contacts.
De-oxit will destroy the lubrication in pots and the resistance element.
You MIGHT try CRC226 which is safe to use. It is available at Home Depot in the electrical dept. Blue can, about $2.75. Make sure it is CRC226 as there are other CRC products there which are not applicable.
The volume control may be damaged now and may need replacement. They are not expensive other than the labor to install it.
Sep 07, 2010 | Yamaha Music
Displays code Scn
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
Jun 02, 2009 | Yamaha Music
Old yamaha electric guitar
Santana's had quite a few guitars, take your pick:
1972 - Gibson Les Paul / Gibson SG Special with Humbuckers / Gibson L-6S
1975 - Gibson SG Special with P90 pickup (Woodstock Festival)
1976 - Yamaha SG 175B / Gibson SG Special with 3 Open Coils
1982 - Paul Reed Smith (PRS) Custom
1988 - PRS Santana II with PRS Santana III nickel-plated pickups and .009-.042 D'Addario strings
Nov 10, 2008 | Yamaha Electric Guitar
Yamaha P90 Digital Piano Logo
18 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
