Question about Frigidaire GLEQ2152ES Electric Dryer
SQUEAKY SOUND WHILE RUNNING
Already REPLACED BELT STILL SQUEAKING WHAT CAN YOU LUBE THE GLIDER WHEELS WITH?
How do I fix a squeaky belt on a minivan?
Post question is automotive section?
Is belt squealing? or is there a squeaky noise?
Squealing would denote belt slippage... belt might be loose, apply more belt tension at idler pulley (if possible). Consider trying a spray-on 'anti-slip" compound.
Squeaky noise could mean a bad pulley bearing.
Oct 13, 2014 | Dryers
How to repair squeaking sound when in operation
it most commonly has to do with the inner wheels needing to be replaced. either the tub wheels or belt wheel.
May 19, 2014 | Maytag Bravos MEDB200VQ 29" Electric Dryer...
Squeaky GE Profile dryer model DPSE810EG5WT
There should be two wheels in the back that may have to be greased or replaced. There are two no friction pads that the drum rests on in the front that need to be replaced every once in a while. Go to searspartsdirect.com or appliancezone.com, with your dryer's serial number you should be able to find the parts.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DPSE810EG5WT/0432/0151200?pathTaken=&prst=0&shdMod=DPSE810EG5WT
or
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Feb 23, 2014 | GE Dryers
Squeaky sound
LUBE inmedIATELY the deck belt +rollers bearings too. If the problem persist time to replace the complete deck belt board.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack Powertread 5.5...
Squeaky sound coming from car. got breaks checked and still squeaking. someone told me it is most likely the wheel bearing
It is possible that it is the wheel bearing especially if it is metal contact you are hearing. To be sure swap your wheels from back to the front and see if the noise transfers location. If it did it could be the wheels.
Jul 21, 2011 | Saturn Ion Cars & Trucks
Squeaking from the drive belts
You can get belt dressing from auto zone which you spray on the belt as it is running and it will lube the belt and stop squeaking.
Hope this helps,
-david
Nov 11, 2010 | 2003 Kia Sedona
My HP 6180 has very squeaky feed wheels. Is there
At the back of the printer is a door. Open door and put some very thin oil(firearm or sewing machine oil works well) either sides of the shaft that the black rollers are on.
Good luck
Jul 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Dryer makes a squeaking noise when running
Check the following:
  1. Idler pulley - It keeps tension on the main drive belt and when it is worn, it can be squeaky and noisy. Replace then.
  2. Glides - Attached to the front bulkhead of the clothes drum for support. When worn, it can be noisy and squeaky.. Replace then.
  3. Rollers or wheels - They support the clothes drum. When they are are worn, you should replace the whole set of rollers at the same time.
  4. Blower wheel - It pulls air over the heat source through the clothes drum past the thermostats, then pushes it out the exhaust duct. It may wear out over time. If it is noisy, it may be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it.
Oct 26, 2009 | Kenmore 84152 Electric Dryer
Broke brand new belt
youve got a pully locking up,all except the crank pully should spin freely by hand if there good
May 25, 2009 | 1988 Oldsmobile Cutlass Supreme
AIR CON
does it squeak regardless if the air is on or not?
Jun 27, 2008 | 2002 Suzuki XL-7
Frigidaire GLEQ2152ES Electric Dryer Logo
27 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
