Question about Novelty Telemania (KARAWAVE) Boombox
How to replace a bulb in a kara wave disco cd player
I bumped it into something and now it dose not work
How do I change lens on Bose Wave CD player
You need to buy the correct replacement lens - usually on ebay is a good selection. Keywords - Bose Laser. Email the seller, and ask for help to identify which lens you need.
Then disassemble your machine, and install the new lens.
If that's too complicated for you, have a local technician do the work.
Dec 15, 2014 | Bose & Wave& Music System
One speaker doesn't work on my bose wave radio/cd?
I can only get one speaker to work continuously. The other works intermittently. If I move the power cord a bit, I can sometimes to get the one "bad" speaker to work. When it's working, the speaker sounds fine. This is driving me crazy. The power cord is new, so I think it has something to do with the power supply. The unit is a '95 Bose Acoustic Wave CD-2000.
Nov 04, 2012 | Bose & Wave& Music System
Not read disk No lee los discos No reconoce los
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it skip.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Take care
Sep 02, 2010 | Denon DCM-370 5-Disc CD Changer
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
Es que cuando pongo un disco me sale no invalido disco con todos los discos que pongo me sale eso ya puse discos originales y no y ayer no pasaba esto que pasa que ao ayudenme porfa
lo que esta sucediendo es que no esta reconociendo ningun disco, es puede ser cause de que el lente esta sucio o roto, trata de limpiar el lente con un cd que se utiliza para limpiarlo y si no funciona pues puede ser que se alla roto el lente. Espero que te alla resuelto el problema.
Dec 29, 2009 | Toshiba SD-P1900 Portable DVD Player
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
Skipping cd deck 2 on numark cd mix 1 player.
paul asked my KAM KCD130 cd deck starts to slow down during playback
Jan 25, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Dec 26, 2008 | Bose Wave Radio
Spin master 3 light bulbs blow on almost every 4 hour disco I do
I too used to purchase a lot of disco items from Maplin, however, I have found that thier products are not always the top of the range you would assume. with regards to any replacment lamp/bulb you purchase from Maplin I have found that they not only go quickly, but the ecl's tend to self destruct and last maybe 2 shows, and at the time they were £10.00 eache. I have since come accross a reasonable seller via ebay who I now purchase all of my replacment bulbs from, and they are boxed as sound lab bulbs, less that half some time a third of the price of a Maplin replacment bulb.
hope this helps
Dec 22, 2008 | Office Equipment & Supplies
No lee discos
Cuando se oye el disco dar vueltas por unos segundos, y despues el lector acaba sin leer el disco con un mensaje 'no disk' , y esto pasa con todos los discos, entonces sinifica que la lentilla laser esta estropeada o bien suzia.
Intente limpiar la lente utilizando un disco limpiador como esto : CD,DVD Cleaner Kit High Quality
Si esso no sirve necessita limpiar la lente directamente con algodon y alcohol, o sostituirla.
Sep 23, 2008 | Yahoo YDP305 DVD Player
Top Novelty Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Novelty Audio Player and Recorder Expert? Answer questions, earn points and help others
