Question about Toshiba CT-90366 Remote Control
Some of the buttons on my toshiba CT90366 rc are not working
The buttons of my remote control are not working, especially the netflix, yahoo, and menu buttons, I need help. Thanks
jerryg50
  • 1689 Answers
SOURCE: Toshiba TV - 29 inch - model 2990 XEL
This may be a fault with the firmware (internal software for the uPC), or it may be a failure in the circuit area or chip that generates the fonts and characters for the menu display.
You will have to send the set for factory level service if this is the case. If you give the set to an independent service center, they may have to send the set out on your behalf.
I would be careful to not invest too much money in to servicing a TV of this generation.
Jerry G.
Posted on Jul 12, 2008
SOURCE: Remote Setup Instructions for Non-Toshiba TV
I need a set of instructions to set my TV remote control (Virgin Meadia) to the Samsung top box
Posted on Oct 24, 2008
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
SOURCE: My remote will not work
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Posted on Mar 19, 2009
SOURCE: Toshiba 57H84 with CT-90233 Universal Remote Control
pic mode bottom left
Posted on Sep 15, 2009
Where is the netflix button on Toshiba Remote CT-90354?
There isn't one. You press the Smart Button and then navigate to Netflix on the screen.
Nov 28, 2016 | Toshiba Televison & Video
Reprogram toshiba remote ct-90302
YA WHY NOT , THIS PROBLEM PERSISTS DUE TO WATER , IF U CAN REMOVE D TOP COVER OF UR REMOTE N CLEAN IT WITH A COTTON WITH OUT USING ANY THING N RE COVER IT N USE IT UR PROBLEM IS SOLVED
Mar 25, 2014 | Kenwood RC-R0720 Remote Control
Toshiba 32A43 - suddenly stopped responding to both my Toshiba CT-90157 remote and Verizon FIOS Philips RC 1445301 remote. Replaced batteries in both remotes & tried to reprogram the Verizon remote...
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
Sep 28, 2010 | Toshiba 32A43 32" TV
I purchased a URC-7940. My NEC TV is working with code 0869. Original remote contreol was a RC-1077E. No provision made on TV to operate colour and contrast; could only be done from original remote...
So the remote that came with the TV was the RC-1077E?The only way you can get into the options you mentioned now is that you are going to have to use the buttons on the TV itself.They can be on any 1 of the four sides.I have seen them everywhere.We have to do the same with our JVC.They are pretty much the same button options as the original remote.Menu,volume,channel etc. Good luck! Greg
Aug 11, 2010 | One For All Stealth TV Remote Control
How to unlock the MENU button on my TEAC RC-1058 remote control
Yes I know press timer and it will take u into the menu........
Jul 31, 2010 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Toshiba Remote control conflicts with another device
I do not know of any possible address changes that can be made but the easiest solution is to put a piece of opaque tape over the IR eye on the device you use the least, the problem being that you can no longer remotely control that device.
The next easiest is to move the secondary device out of the line of sight and then just aim the remotes at different locations.
Feb 27, 2009 | Televison & Video
I have a Toshiba 27WLT56B. A year ago it developed a problem: (1) I have to switch it on from the buttons on top of the TV. (2) Only after 10 minutes does it respond to the remote control (RC). (3)...
there it is a complicated problem your tv seem to have one big problem with the supply module inside him the power current was accidentaly increased and now your tv dont respond better and your picture is enlarged because had a big alimentation current and now you must to go in authorized service to fix that problem
Dec 11, 2008 | Televison & Video
Tv turning back on when turned off.
Thanks for helping me understand this problem. I've placed new batteries in the RC but, that don't help. It's the RC that came with the TV when I purchased it new.
bessylou4@yahoo.com
Aug 12, 2008 | Televison & Video
Remote Control for Denon AVR-5800
I have 2 Denon Universal Remote RC-8000 AVR for sale if you like you can send email Shavoniemail@yahoo.com
Thanks, Scott
Oct 24, 2007 | Denon RC-8000 LCD Touchscreen Remote...
Toshiba CT-90366 Remote Control Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
