Question about Exercise & Fitness
Run tec swing stepper manual
Missing manual for computer function
Printing on TEC b-572 pauses
DEFAULT SPEED IS 9600 bauds, 8 data bits , 1 stop bit no parity.
Un fortunateley the best spped avaible is 19200 bds.
The pausing is due to too much data transfered trough the serial port.
To sole this, increse tehe baudrate and use internal fonts.
Aug 06, 2014 | Toshiba TEC B-572 Printer
Why is my Viking Prisma 940 only sewing straight stitch - none of the patterns are working
1. the twin needle button is turned on ( good news). (not sure if this is a function on 940 just check because it is simple to see.
2. the zig zag stepper motor or controller is non functioning. (new computer board or stepper motor) bad news no longer available
May 27, 2014 | Husqvarna Sewing Machines
I lost two screws and the manual to the swing
If you have one of the screws that you are missing, you can take it to any hardware store to show them the size and it' should be pretty easy to buy replacements.
If that is not an option, you can contact Disney and as well as the manual, you can ask for the screw size.
Feb 14, 2013 | Disney All-In-One Swing My Friend Pooh
Engine swings but does not start
Your engine needs basically four things in order to start:
> Volumetric efficiency (V)
> Air/fuel ratio (A)
> Compression (C)
> Ignition (I)
V + A + C + I = POWER
When there is no POWER (engine will nor start or run), it is because one of the parts of the equation is missing. PRELIMINARY diagnosis is to determine which parts of the equation are present and which are missing. Then PINPOINT diagnosis is to determine WHY the missing parts are missing.
Until pinpoint testing is completed, nobody can do anything but GUESS what is causing your engine to not start.
Jun 01, 2012 | 1998 Subaru Forester
Error 59 co in 5550DN
Hello thanks for using fixya
59 C0 error code usually affects the printer motor. The problem can range from a couple of issues that occur within the printer's motor. It can also be a cartridge issue. Depending on the printer and which manual the user is referring to, the solution to fix this error varies.
  1. Error code 59 C0 due to problems with printer motor
  2. Error code 59 C0 due to problems with cartridges
  3. Error code 59 C0 due to broken back sliding lock
Error code 59 C0 due to problems with printer motor:
This is referred to as "developing disengaging motor rotation error" Most likely, this problem points to an issue with the function of the DC controller either it has failed or it has affected the developing disengaging assembly.The solution is quite simple and you may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller).After connecting these two connectors to each other,you must replace the developing disengaging drive assembly directly.The final step is to replace the DC controller PCB, after which the printer is to be recalibrated.
Error code 59 C0 due to problems with cartridges:
Another more complex problem that leads to the 59 C0 error code is a problem with the cartridges.You must first remove all the printer cartridges in order to view the right swing guide. Once these have been removed, you must check for certain parts in the printer, which mostly resemble upside-down. If you finds that the swing guide does not move all the way backwards,then the most likely problem is a missing plastic component of the swing guide. This part also resembles an upside-down T.
Another problem that may cause the error to display is when the black sliding lock is broken out of place or missing its spring. If any of these cases, you must replace the swing guide completely. You should attempt to locate the missing piece within the printer so that it does not cause further problems in it. If the swing guide does function properly, then gently close the door, paying close attention to the right side of the printer's swing arm.If the right side swing arm closes in the same manner as the left side swing arm, then your printer is functioning just fine and you may simply need to turn it off to fix the error.If the right swing arm does not close properly, then the machine should be serviced by a professional to fix the problem.
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Jan 10, 2011 | HP LaserJet 5550DN Printer
Nikon LS-2000 scanner gives error 0x04620000
Stepper Motor Failures
Within the first 6 months of purchase I had to return the scanner twice to replace the stepper motor. The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
service required to fix stepper motor
Jan 07, 2009 | Nikon LS 2000 Film Scanner
Exercise & Fitness Logo
107 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
