Question about Microwave Ovens
What is the cooking wattage of glmv168ks4 micowave
Cooking wattage
Wattage for mc 1000b microwave
By the name I would think that it is a 1000 watt Microwave. Wattage as in cooking power is what you wanted? Running wattage, a 15 amp circuit will work fine. A 120 volt, 1000 watt microwave will use 13.4 amps (1,600 watts) of electricity in a full power cooking cycle. I think that covers everything! ..:)
May 16, 2014 | Magic Microwave Ovens
I need to know the wattage of my magic chef oven model 6898VV
Hi Nadia,
There's little to be found on the internet for this model oven now. There should be a name plate / manufacturer's sticker either inside the door - on the jamb; or on the rear near the power cord. If you see a rating given as "120VAC / 1200W" this would indicate INPUT wattage, which would be higher than the amount used for cooking. A typical 1200W rated microwave might have 800 - 1000 Watts of cooking power. If there are 2 ratings for wattage like 120V / 1200W / 850W; the 850 Watts is the amount of cooking power. The cooking power - or wattage - is always lower than the total wattage. If you see a rating somewhere that indicates 900W cooking power, then that would be the cooking power of the oven.
If you're not satisfied or unsure about the information you're finding on the oven - or it is missing - you might want to contact Magic Chef Customer Service Department at (888) 775-0202. They should be able to help you - or pint you in the right direction.
Apr 07, 2014 | Magic Microwave Ovens
Numeric keypad doesn't work on my microwave oven
if it got wet from cleaning just wait if its real old its more than not wore 0out
Mar 31, 2013 | LG Microwave Ovens
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
Power comes on but micowave does no cook
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Emerson Black Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Panasonic Inverter Micowave only runs for four seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Dec 24, 2008 | Microwave Ovens
No cook mode
check control circuit, and check highvoltage section, and all the door lock switches, and sensors, chaeck over all circuit..
Oct 07, 2007 | Panasonic NN-S540BF Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
