Question about Kocaso M9300 Google Android 4.2 capacitive 9 Dual Core 1.2GHz 8GB Dual Camera Tablet PC-Pink
Frozen tablet My tablet is frozen. I tried hitting the reset button on the back and it did not work. I also opened the tablet to locate the reset button and do not find it. What can I do to reset my table
  • Kocaso Master
  • 2,219 Answers
There is no reset button. The reset is performed by the power button, Press and hold for 6 seconds to reset the device.
Here is the manual
http://www.kocaso.com/manuals/M9300/M9300_User_Manual.pdf
Posted on Feb 22, 2015
Tablet frozen, how do i reset?
Press and hold the power button for at least 10 seconds, then release. If that doesn't work, there is a reset hole at the back of the tablet which you should insert a paper clip into.
Jul 03, 2016 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
I can not get get to the first screen on my nextbook, it is charge and it stays totally black
I am not directly familiar with your particular tablet, but try this.
Locate the reset button's access hole - usually a tiny hole either on the back of the tablet or on the edge near the various ports and connectors. If you have a manual for the Tablet, it should tell you the location of the Reset button.
  • Press the button by inserting a paperclip or similar GENTLY into the hole. PLEASE MAKE SURE IT'S NOT THE MICROPHONE HOLE YOU"RE LOOKING AT.
  • You should feel a soft click when the recessed 'Reset' button is depressed. Hold it down for about 10 seconds, after which the Tablet should reboot itself, and hopefully will now run normally again.
  • Note that you WILL NOT lose any data or settings by resetting your Tablet this way - it merely restarts the microprocessor which may have frozen.
Dec 30, 2014 | Nextbook Tablets & eReaders
How to get back to settings on frozen samsung tablet
Tablet should have a "reset" button on top or side. Small hole. You need an object that would fit--it will take it back to factory specs. Make sure tablet is fully charged--or plugged in first. Worked for me.
Sep 06, 2014 | Samsung Tablets & eReaders
How do you open a double power 7 inch tablet to remove battery
Have you tried holding in the power button for approx. 15 seconds. This should force the tablel to switch of. Then just switch it on again
May 29, 2014 | Double Power 7 inch Tablet with 8GB Memory
Tablet has frozen-have tried the reset on back with no success
If your tablet freezes, or in any other way does not react, you can force it to turn off by pushing and holding the power button for 15 seconds.
If this doesn't work, use the 'pinhole reset button' when available. Get a paperclip and use it to gently push the reset button on the backside of the unit. *Note- above information taken directly from Polaroid site.
Mar 17, 2014 | Polaroid Tablets & eReaders
How do i reset. the screeen is frozen
Try pushing the reset button in the TINY hole in the back of the tablet.
Dec 12, 2013 | Kocaso SX9701 Android 4.0 9.7" Tablet PC -...
How to reset android tablet
There is a reset button on all Android tablets, it's usually located behind a small hole on the back of the tablet or adjacent to the in/out connectors. the button can be depressed using something like a straightened paper clip inserted GENTLY into the hole. This may work. However, from the error message you have it seems likely that you may have crashed firmware, probably caused by a faulty Read Only Memory chip on such a new tablet.
Take it back to the store for an exchange if this is the case, as tablet PC's are generally unrepairable at the component level.
Oct 24, 2013 | Tablets & eReaders
Emerson tablet touch screen is frozen. How do I get it to work?
There is a tiny reset hole on the back of the tablet marked with a "R" near the SD card slot. Push a small paper clip in the hole until you feel it hit the button. This will reset the tablet and the touch screen will start working again once you power it back up. --Emerson m744 android tablet.
Dec 04, 2012 | Tablets & eReaders
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Kocaso M9300 Google Android 4.2 capacitive 9 Dual Core 1.2GHz 8GB Dual Camera Tablet PC-Pink Logo
160 people viewed this question
Top Kocaso Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
David Payne
David Payne
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
