Question about JVC Ks-bta100 Bluetooth Adapter For Select In-dash Head Units/receivers
For the ks-bta100 where does the brown wire connect ?
My 2006 chevy silverado hd 2500 is showing a p0332 code how do i fix this? it has a 6.0 motor ext cab
code p 0332 refers to knock sensor(KS) 2 banbk 2--low input===causes --insecure KS--poor connections ---wiring short to ground--KS incorrectly tightened---KS---ECM
Jun 09, 2017 | Cars & Trucks
What is bluetooth adaptor for jvc kd s28
According to the installation manual for the KD-S28, the bluetooth adapter is KS-BTA100. You can find this on page 2 of the installation manual which is available from JVC's support page: http://books.jvc.com/ . Enter the model number and click the Model Search button. The direct link to the installation manual is http://books.jvc.com/Download/119824748/GET0754-002A.pdf .
I hope this helps. Amazon has a couple of the adapters for sale: https://www.amazon.com/JVC-KSBTA100-Add-On-Bluetooth-Adapter/dp/B004REMUJE . Other vendors do not report having this in stock.
Mar 27, 2017 | JVC Car Audio & Video
How do I fix code PO327 Knock Sensor 1 Circuit Low Imput Bank 1.
code p 0327 refers to knock sensor (KS) 1 bank 1---low input===causes ---insecure KS, poor connection---wiring short to ground---incorrectly tightened---KS---ECM
check all the wires for good connections and the fitment of the KS
replace the KS if all other items check out ok
Dec 14, 2015 | 2004 Infiniti G35 Sport Coupe
How can I make it blue tooth
http://www.manualslib.com/manual/450459/Jvc-Kd-R530.html?page=10#manual
According to the above link for the manual, you require a KS-BTA100 adapter that plugs into the rear of the unit
Hope that helps
Oct 05, 2015 | JVC KD-R530 In Dash Stereo
I have a JVC KD-S29 RADIO AND I AM TRYING TO GET THE BLUETOOTH TO PAIR WITH MY PHONE AND I CAN'T GET IT
It is not bluetooth ready. Not sure you can use the BT adaptor KS-BTA100. Will let you know tomorrow.
Feb 22, 2015 | JVC Car Audio & Video
Turn on the Bluetooth on the ke-s39
It needs a blue tooth adapter KS-BTA100
Dec 30, 2014 | JVC Car Audio & Video
Proper color for jvc 320 to jvc ks-bta100 hookup
There are only 3 POWER cables to worry about and one 3.5 aux. BLACK, BLUE, AND BROWN. Tap existing connections. on back of harness and connect 3.5 aux to back on unit.
Feb 14, 2014 | JVC KD-S5050 CD Player
Jvc car radio won't mute on incoming calls
I think the only hope you may have is the radio has an auto signal select in the menu somewhere. You can't use the mute wire as that will mute the AUX as well.
Dec 08, 2013 | JVC Ks-bta100 Bluetooth Adapter For Select...
JVC Ks-bta100 Bluetooth Adapter For Select In-dash Head Units/receivers Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
