Question about Samsung TXH1970 TV
No remote; cannot receive cable
I was given a TXH1970 TV.  No remote was included.  The cable connection in the room works fine on a different TV.  I plug the cable into the back of the TXH1970 and get 3 or 4 stations and indication that it is "AIR" or "ANTENNA".  Pushing the menu button on the TV gives me some choices but does NOT allow me to switch to cable.  There is only the ONE cable connection at the back and the A/V jacks.  Suggestions
  • Arieh Oct 31, 2007
    I forgot to mention that I did buy a universal remote and it does work on another TV, but NOT on this Samsung.  Sorry for not mentioning it first time.  Shall we try again
  • Anonymous Mar 27, 2014
    Menu want allow to lock in tv mode keeps switching back to cable mode
Latino, thanks once again for trying to solve this problem.  I called Samsung and they said "universal remotes do NOT work with the on-screen menu.  However, I then plugged the cable in (did that the first time) and tried the on-screen menu when it was on a channel, not just a "snow screen".  The menu worked with the TV buttons and I am now successfully receiving all the cable stations I desire!
Posted on Oct 31, 2007
  • 93 Answers
Get a universal remote it should work
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
Have a vip625 receiver i want split the tv1 signal and use the remote in another room
kdsix,
You can split the signal from TV1 if it is connected via a coax cable. All you would have to do is run that TV1 connection into a 2-way splitter, then run a connection from each of the ports to a different TV.
The TV1, however, is still IR so you wouldn't be able to change channels from another room unless it has a clear shot to the receiver. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Oct 20, 2012 | DISH Network ViP622 DVR DTV Receiver /...
I have a jvc LT42P510 tv and it is hooked up to a Dish Network 722k hi-def dvr receiver, the dish remote will not function in the dish mode, for example when the dish receiver is plugged into the tv using...
hi,
Check the version of the hdmi cable you used. Try to use hdmi cable version 1.3 or above . Also try hdmi cable with version 1.2 .Version of the cable is very important one.
ok
Mar 04, 2011 | JVC LT42P510 42 in LCD TV
Hello! I haven't a problem Yet! I am contemplating buying a used "owned" Dish single tuner PVR 508 and adding it to my current configuration. My home is 2 years old and wired for cable in 5...
Hello, this Luke. Hooking the 508 to any TV is just like hooking a DVD to TV. Just used whichever cable available to you. e.g. RCA, coax. But if you want to have Satellite programming to that receiver, that would be a different thing. You will have to call Dish to add that receiver to your account with them. They will verify that receiver if it is registered to an account with debt and add it to your account if it is clear. They might need to send an installer to hook it up. Let me know if this help.
Jan 26, 2011 | Televison & Video
I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Mar 11, 2010 | Onkyo TX-SR502 Receiver
The remote will not operate the tv but will operate one in another room.The tv works fine manually operated.The remote just stopped working. Could the receiver in the tv be bad?The unit is a little older...
are you on sattilite or cable, and is this the remote you're using? I had this prob once. Somehow the 2 remotes got swapped...the tv that worked probably belongs to the remote that worked...try each of the remotes on each tv.
Mar 07, 2010 | Sharp Televison & Video
I am connected to shaw cable bc. For several days
Take out the cable signal,put ur tv in the cable mode u get a statics siginal,but can u get 100 and up in channels numbers?U hook the pay cable back u should solve the prob.
Aug 19, 2009 | Televison & Video
2nd remote has trouble changing channel
hook up a 6 foot peice of coax cable to the remote antenna port and then attach a barrel connector and then use a larger antenna "bunny ears" basically to extend distance of uhf signal for remote
Nov 27, 2008 | DISH Network DVR-625 DTV Receiver /...
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
TV & Receiver at opposite sides of room
hello mike if no one has answerd this then here you go u may want to look in to an IR Extender 2 wires to hook up and easy to hide you can find them about anywhere. good luck
Please rate
Nov 21, 2007 | RCA DIRECTV Satellite Remote Control
Samsung TXH1970 TV Logo
93 people viewed this question
Jerry Greenberg
Jerry Greenberg
