Question about Black & Decker D6000 Iron
D6000 stopped working
Won't heat
Auto shut off light keeps blinking does not steam
Here is the manual it might help. sometimes they need to be cleaned out from hard water. It best to use distilled water so no lime deposites build up
http://cdn.spectrumbrands.com/~/media/HobbsUS/Black%20and%20Decker/Files/D6000%20Use%20and%20Care%20Manual.ashx
Jan 28, 2015 | Applica Black&Decker D6000 Steam
Steam switch won't work
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
God bless you
Apr 01, 2013 | Rowenta Irons
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
My iron's MODEL: 14977Z The iron's red light is on but won't heat to iron. was working a couple of hours ago
This is typical of a iron, it is cheaper to replace than to repair. The heating element is broken.
Jun 02, 2011 | Hamilton Beach 14977 Iron with Auto...
Iron keep shutting off while ironing
The cord is broken...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jun 21, 2010 | Black & Decker Steam Xpress AS250 Iron...
Black & Decker D6000 Iron Logo
Top Black & Decker Irons Experts
tfelton3
nmccully
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
