Question about Hardware & Accessories
How to reset a danfoss t4000
Tried resetting but the screen is frozen
  • 39 Answers
SOURCE: Screen frozen with vertical lines
http://pocketpccentral.net/help/dellx3reset.htm
Posted on Aug 27, 2007
  • 1111 Answers
SOURCE: magellan maestro 3100 frozen on blue screen tried
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Posted on Jul 19, 2009
  • 846 Answers
SOURCE: non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 08, 2010
SOURCE: HTC Touch Pro 2 - screen frozen - how to fix prob??
I have a similar problem with my HTC Touch Pro. A hard reset didn't work either!
Let us know if you get an answer!
Posted on Jun 10, 2010
SOURCE: My Garmin Nuvi 660 touch screen is frozen. I've
Sounds like your firmware needs updated. Just go to Garmin’s website then downloads and update your firmware. As long as there is no screen damage but just touch screen not working that will fix it. An easy test is to take out the battery and if the unit works for second then freezes you just need to update firmware. Turn off unit plug into computer via usb cable and do firmware update, that easy!!!! Hope that helps?
Posted on Aug 22, 2010
Won't let me sign in : screen appears to have frozen. Turning it on and off does not help!
Perform a hard reset by pressing and holding the power and volume up buttons until the unit resets.
Mar 18, 2015 | Nokia Lumia 2520
My rca m6204 mp3 player is frozen and resetting it doesnt work
Extremely lucky i am,like a idiot i tried to format/delete all my songs on my M6204 RCA mp3 player then it was taking to long to load then i reset it with a tooth pick,then i tried to turn it on and the intializing screen said please wait,and was frozen their,i got extremely upset since it's my only music device i have i actually cried,anyway what i did is locked the screen then resetted it,while it was in reset mode,i plugged in the USB connector,and then i downloaded
Firmware Update/Restore Utility
the link to the site is here: http://www.rcaaudiovideo.com/downloads/?sku=TH1611
Hope this helps.
May 18, 2012 | RCA M6204 Video Mp3 Player With 2.0" Color...
Sep 22, 2009 | Computers & Internet
Magellan 3100 frozen on blue screen with black progress bar
where are you getting that error message, on the pc or the 3100
Aug 05, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
Creative Zen frozen and Reset has not worked
You probably shouldnt play with any of the buttons really but i know how to fix it. You hold down the slide power for about 5 seconds and poke the reset button with a pen tip or w.e for about another 5 seconds till it restarts itself.
Mar 28, 2009 | Creative Labs Zen Digital Media Player
Danfoss thermostat control frozen at 20 degrees showing room temperature 25 degrees when room temperature not that hot
See the link on the Danfoss site.  This has helped me http://heating.consumers.danfoss.com/xxNewsx/5dbcb2f9-e888-4d2d-9761-7470786749c9_CNP1.html
Nov 07, 2008 | Heating & Cooling
Completely frozen
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET printer reset
4)OK
Sep 13, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Locked up HP Ipaq Pocket PC
find your manual and use the default password since the unit had been reset.
Aug 18, 2008 | HP iPAQ H1910 Pocket PC
Frozen! Help pleaseeee!
While it's on the SAMSUNG screen, hold down the reset hold for 10 secs until it shuts off.
If it doesn't work, try resetting it while it's connected to the PC.
Jul 24, 2008 | Samsung YP-K3 MP3 Player
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
