Computers & Internet Logo
endk enduj Posted on Mar 30, 2014
Fix my register
Activation key
Cannot re-register Vertus Fluid Mask software, which I already own
Hi aaliceronm,
Please follow the instructions below on how to register/activate your Vertus Fluid Mask software.
Vertus Tech provides two ways of registration/activation:
Fluid Mask 2.0: In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three months).
Fluid Mask 3.0: For Fluid Mask 3 they offer two ways of registration and activation of your full Fluid Mask license:
Online registration:
This option requires an active internet connection on the machine on which you are installing Fluid Mask.
1. If you already installed the trial version of Fluid Mask please open Fluid Mask and go to > Help > Register.
2. Fill out the registration form and insert your serial key. The serial key should have been sent to after you placed your order for Fluid Mask 3 and has the format
01AXYZB0B123F123CDA7121234567AF123
Please make sure you copy/paste the serial key into the serial key field to avoid typos or mixing up digits and letters like 0 and O etc.
3. Click on the button to send the information.
4. The registration takes a few seconds. If it was successful you will see a pop-up window confirming that you are now registered.
5. You can either copy and paste your information from there into a file or to create an e-mail.
6. In addition you can see the message "You have a full license" when going to > Help > About Fluid Mask.
Registration by e-mail:
3. Click on the button to send the information. The registration takes a few seconds.
4. If Fluid Mask cannot detect an active internet connection or could not complete the registration for other technical reasons, then Fluid Mask will display your registration information in a new window.
6. Please send the complete information displayed to [email protected]. It is important that the information we receive is complete and correct.
They will process your registration as soon as possible and provide you with a license code by e-mail. You can then use this license code to activate your full Fluid Mask license under > Help > Register in Fluid Mask 3.
^return to top
Do I need an active internet connection?
Fluid Mask 2.0:
In order to register Fluid Mask 2.0 you need an active internet connection on the machine you want to use Fluid Mask on. This machine does not have to be online continuously after registration. Fluid Mask will try and re-connect periodically to validate your license though (every three month).
Fluid Mask 3:
Fluid Mask 3 does offer an online activation. For those users who don't want to connect their workstation where Fluid Mask is installed to the internet we offer an activation by e-mail, too. Instructions are displayed in the software during the registration process.
Hope it helps.
Thank you for using FixYa.
4answers
Unregistered windows xp, I have the key how do i register it
How to activate Windows XP by using the InternetTo activate Windows XP by using an Internet connection, follow these steps:
  1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Or, click the Windows Activation icon in the notification area.
  2. Click Yes, let's activate Windows over the Internet now.
  3. Click Read the Windows Product Activation Privacy Statement, click Back, and then click Next.
  4. Use one of the following methods:
    • If you want to register and activate Windows at the same time, click Yes, I want to register and activate Windows at the same time, click Read the Windows Registration Privacy Statement, click Back, click Next, type your contact information in the appropriate boxes in the registration form, and then click Next. An asterisk (*) appears next to required information.
    • If you only want to activate Windows, click No, I don't want to register now; let's just activate Windows, and then click Next.
    The wizard establishes a connection with an activation server, and then processes the activation request.
  5. When activation is completed and you receive the following message, click OK: You have successfully activated your copy of Windows. *microsoft.com
2helpful
If a key is typed twice in a row the 2nd one wil not register and another key must be hit before the other can be presed again
It's possible you have activated one of the Accessability options.
Go in to your Control Panel, Open Accessability Options.
On the Keyboard Tab, see if Filter Keys is active, or even Sticky Keys.
If so Clear the check box for that item and hopefully that will fix it.
Windows 7 ultimate activation
If the key has been registered to you then you can contact Microsoft and they will be able to get this fixed.
283helpful
18answers
1helpful
2answers
Lost CD-KEY for cyberlink powerDVD
hi,
Following is what , i gathered information from cyberlink source
What can I do if I lost my activation key?
Before contacting customer support, try to locate the activation key through the following steps:
If you have registered your products: If you have registered the software, you can log in CyberLink Members Zone and select Manage My Products in the left menu, and then click Manage CD-Keys tab. You will see all the keys you have registered before.
If you haven't registered the products: Retail or boxed versions: If you have a retail or boxed version, the CD sleeve/case should have an activation key sticker attached to it.
Online/Download version: If you have the online/download version, you can check your email inbox for your order confirmation e-mail. It provides you with the product key.
Bundled version: If you got your software free as a bundled version, the CD sleeve/case should have a sticker attached to it. If not, please contact the hardware supplier to get a new key.
If you still have no luck locating the activation key, you will have to register as a CyberLink Member and submit a technical support form to ask for a new key. You will need to attach a digital or scanned image (in .jpg format) of your installation disc as the proof of ownership of the original software copy.
Note: If you are reading this prior to having lost your key, then we strongly recommend that you register your software as this will keep your activation key safe and available if you ever need it. You can always find Online Registration shortcut in the CyberLink program folder of Windows Start menu
1helpful
I have lost my serial key for power dvd 7.0 .can any one help me?
From their FAQ:
"What can I do if I lost my activation key?
Note: If you are reading this prior to having lost your key, then we strongly recommend that you register your software as this will keep your activation key safe and available if you ever need it. You can always find Online Registration shortcut in the CyberLink program folder of Windows Start menu."
http://www.cyberlink.com/prog/support/cs/faq-content.do?id=2325
2helpful
2answers
Activation key
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step 1
Obtain the serial number for your security appliance by entering the following command:
hostname# show activation-key
Step 2
Access one of the following URLs.
Use the following website if you are a registered user of Cisco.com:
http://www.cisco.com/go/license
Use the following website if you are not a registered user of Cisco.com:
http://www.cisco.com/go/license/public
Step 3
Enter the following information, when prompted:
Product Authorization Key (if you have multiple keys, enter one of the keys first. You have to enter
each key as a separate process.)
The serial number of your security appliance
Your email address
An activation key is automatically generated and sent to the email address that you provide. This key
includes all features you have registered so far for permanent licenses. For VPN Flex licenses, each
license has a separate activation key.
Step 4
If you have additional Product Authorization Keys, repeat Step 3 for each Product Authorization Key.
After you enter all of the Product Authorization Keys, the final activation key provided includes all of
the permanent features you registered
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
