Question about Cartier Tank Francaise W51001Q3 Wrist Watch
160029cd 2403 which tank model is this
My lighter will not fill,,the gas keeps on hissing out of it..cartier
it seems that it is stuck open, did you drop it? or maybe got some kind of a liquid (containing sugar) on it?
Oct 29, 2014 | Watches
Cartier Women's Tank Watch
What has been the issue when the repairs have been done? My experience with Tanks is that any reputable watch shop will replace the battery for $20. I don't know why it has cost you so much, but if the model you have is an auto-winder, then there is no way to retrofit a battery - although for $600 someone may be able to change the internal watch out completely.
Jan 31, 2014 | Cartier Tank Francaise W51001Q3 Wrist...
Where can I buy a new reservoir for my cartier lighter
I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
Jan 29, 2014 | Cartier Tank Solo Watch
I have a Cartier Tank Francaise, and the clasp seems to be loose, as it keeps opening up. The watch is about 10 years old already.
replace the clasp, I see it all the time in this model watch. I usually charge $50.00 for the clasp for these watches, It can be adjusted but it will loosen within the next year or less.
Dec 02, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
Ladies diamond tank black, model JWC036T. I need to buy some additional bracelet links - about 1 inch.
mcdevito75 here, Look for a small watch repair shop in your area for these extra links.
Jul 28, 2010 | Watches
My cartier tank is difficult to wind. The step is
Your watch is a quartz type that does not need winding.
If you go to their web site (http://www.cartier.co.uk/#/show-me/timepieces/w51011q3-tank-fran%C3%A7aise-watch-medium-model?tab=2" and you will see details of your model.
May 07, 2010 | Cartier Tank Francaise W51001Q3 Wrist...
WHERE CAN I GET A RESERVOIR FOR MY CARTIER LIGHTER
The reservoir tank can be the bane of existence for a Cartier lighter owner. Unlike most butane lighters which have gas tanks integral to the lighter, Cartier utilizes a user removable tank. Cartier only warrants the tank for two years. I've also seen tanks that say 12 months. New Cartiers come with one spare tank. I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
Jul 16, 2009 | Cartier Tank Solo Watch
Need to know how to operate Cartier Tank Francaise Chronography W
The top button is for chronograph function and puts the chronograph seconds hand in motion. The bottom button is for resetting chronograph seconds hand to zero.
Do as follows:
1) push the top button once- seconds hand starts moving,
2) push the top button once more- seconds hand stops,
3) push the bottom button once- seconds hand returns to zero.
You can repeat as many times as you like- seconds hand will allways start the countdown from zero.
Depending on what movement your watch has(mechanical or quartz), there can be more variations, but the basics are as described.
If you need more info, supply full info of your watch(make, model, numbers, etc.), please.
Do not forget to rate, please.
Jan 10, 2009 | Cartier Tank Americaine W2601156 Wrist...
Cartier Tank Basculante Reverso Watch
Yes, it has a small second hand and dial at the 3:00 position, and the date is at the 6:00 position.
Apr 23, 2008 | Watches
Cartier Tank Francaise W51001Q3 Wrist Watch Logo
13 people viewed this question
Top Cartier Watches Experts
k24674
Jimmy Accardi
Are you a Cartier Watch Expert? Answer questions, earn points and help others
