Question about Samsung RFG297HDRS Stainless Steel
Rfg297hdrs ice maker
My Samsung refrigerator Model RFG297HDRS-XAA has 15-E code flashing.
Existing error codes for Samsung fridges run from 1 up to 13, in the majority of models as far as I could find out.
You might be having two error codes instead of one code
error 1 and Error 5.
Error 1 refers to 1. Ice Maker Sensor:
Ice Maker sensor connector missing, contact failure, electric wire cut, short-circuit, Ice Maker sensor failure.
Indicates an error when the temperature sensed by Ice Maker sensor is higher than 150 or lower than -58.
Error 5 refers to 5. Ice Maker Function Error:
Ice ejector and level failed three times or more.
Jul 12, 2017 | Samsung Refrigerators
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    Samsung model RFG297HDRS manual
    then you need a repairman . or a new one
    Oct 22, 2015 | Samsung RFG297HDRS 29 Cu Ft Stainless...
    Samusung RFG297HDRS Ice maker not cold enough to produce ice.
    Suspect that the rubber boot that runs all around the edge of your freezer door is deformed, allowing warm air to seep into your freezer. You will see where your temp sensor is located by clicking into the site of a parts supplier like ShopJimmy.com and pulling up their photo of the guts of your unit.
    Oct 29, 2014 | Samsung RFG297HDRS Stainless Steel
    Why does my ice maker not get cold enough to produce ice? I have a Samsung RFG297HDRS French Door refrigerator. Everything is functioning except for the ice maker. Water is getting into the ice maker
    Ok Randy, Lets fix it.
    My name is Peter. I am a retired refrigeration field service technician.
    You are not getting cooling air to your ice maker freezer compartment. Once again Samsung - bad design - put a ice maker in the fresh food section.
    So, you have a ice maker enclosed next to the fresh food section where the recommended temperature setting is 35-40 degrees F.
    Where as your recommended freezer temperature is +2/-2 degrees F.
    There is a air damper/vent from the bottom freezer in the back of your ice maker housing. Lets remove the ice maker to check for ice build up. On the left hand side of the housing on the wall there is a long narrow cover plate. This is where you connector harness is located. There are 2 screws holding the front end in and a tong and groove tab in the back. Remove the cover plate.
    Now, pull the harness out.
    Lets remove the ice maker assembly. There are two screws in the front end securing the ice maker to the top of the casing. These screws are recessed. They are either Philips heads or hex heads (1/4"). If they are hex head, he recessed hole diameter is small. Some hex head hand tools will not fit. A screw gun will work or a small outside out side diameter hex head hand tool.
    Remove these screws. In the back in each corner is a tong & groove. Pull forward to release the ice maker. Using a small flat head screw driver wedge the wire harness to release. Set the ice maker aside.
    Inspect the air vent/damper for ice build up. Use a hair dryer to defrost.
    I do not believe you have a automatic damper controlled by a thermistor (temperature sensor). If you do, Remove the damper assembly. Get your multi-meter. Set your meter to the lowest Ohm reading (Omega on your meter) Touch the two probes on your meter together, you meter should read 1.0. Disconnect the 2 motor contacts. On the motor place one probe on one contact and one probe on the other contact. If the meter still reads 1.0 the motor is bad. If the meter reads 0-50 Ohms the motor is good.
    If there is no ice buildup & the damper motor checks out, replace the temperature sensor.
    You will find getting the wiring back into the side panel will be a little difficult. As usual, Samsung is not service friendly.
    Oct 22, 2014 | Samsung RFG297HDRS 29.0 CuFt French Door...
    Locate ice maker water level control?
    This should be automatic. What is the problem--too litte ice? Do you have a in line water filter out side of unit? Filter in the fridge? Check for dirty filter and you may fix the issue of not enough water getting thru.
    Jul 16, 2014 | Samsung RFG297HDRS Stainless Steel
    Ice maker
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    other ice maker related issues and solutions:---
    Ice maker dispensing ice with black or white plastic pieces in ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
    After replacing ice maker assembly, ice is not getting made?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
    Ice maker is leaking water and causing the ice to freeze?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    Refrigerator ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
    Ice maker leaks water into ice bin causing a glob of ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
    Amana Refrigerator leaking water from ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
    Ice maker leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
    Ice maker is dumping the ice cubes out before frozen solid.
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
    Water overflowing ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
    Ice cube is getting stuck up hard in ice maker
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
    Icemaker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
    Quit making ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
    Water leaking into ice tray, frozen glob of ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
    Not making ice, and water leaking in freezer?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
    The ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
    Ice maker not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
    Ice maker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
    Ice maker dispensing black pieces of plastic in the ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
    Replaced Ice maker but its still not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
    Ice maker leaked creating an ice block?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
    Ice tray leaked?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
    Ice maker stopped functioning?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
    Ice maker stop working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
    Ice maker failed
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
    Old ice maker stopped working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
    Old ice maker started leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
    Ice maker not working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
    Ice maker overfills and cause water to flow into ice dispenser and freezes?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
    Ice maker didn't make ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
    Ice maker was leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
    Ice maker was leaking after it filled up with water?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
    These will help.
    Thanks,.
    Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
    GE Ice Maker freezing
    Not sure exactly what you mean by the ice maker freezing, ice makers are suppose to freeze. But if you are referring to the ice maker not being able to harvest the ice since it is frozen in there to tight, then the heater that is on the bottom of the ice maker has failed and you will need to replace the ice maker.
    Here is a link to the new ice maker.
    Oct 15, 2012 | Refrigerators
    Samsung RFG297HDRS Stainless Steel Logo
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
