Question about Epson SD-621L 1.2mb Internal Floppy Drive beige P/N: SD-621L - Epson
Epson sd-621l jumper settings
Settings to determine drive1 or drive0
    Novelist:
  • 242 Answers
Drive is determined by placement on the cable, not jumpers.
Posted on Dec 04, 2014
Western digital wd2500bevt slave jumper settings
SATA drive position is determined by the plug on the motherboard, not a jumper. Jumper settings are for PATA drives (much older).
Feb 06, 2014 | Western Digital WD Scorpio Blue WD2500BEVT...
How do I slave a cd-rom drive in a dimension 1100
Most CD or DVD drives installed in modern computers have a group of short jumper pins on the rear of the drive that determine the master or slave setting for the device. The master or slave setting helps to identify the drive when it shares a connector cable inside the computer with another device, such as a hard drive or even another optical drive. Without the master or slave jumper setting, the computer would not be able to tell one device from another or from which drive to retrieve or write data. Configuring a CD drive as master or slave is a relatively simple task that takes only a couple of minutes.
Turn the CD drive so that you view the rear of the unit, then check the position of the jumper covers on the set of pins next to the power adapter plug. If the CD drive will be the only device on the IDE data ribbon cable, set the jumper cover on the two pins farthest away from the power connector. This position is the master drive setting, and, by default, most CD drives ship with this configuration. In most cases, if the CD drive is the only device connected to the cable, you do not need to change the jumper setting. Determine if you need to change the CD drive jumper setting if the device will share a connector cable with a hard drive or another optical drive. If the CD drive will be the primary (master) device on the cable, do not change the jumper setting. If the CD drive will be the secondary (slave) device on the cable, continue to the next step to change the setting. Use a pair of needle-nosed pliers or your fingers to remove the jumper cover from the CD drive if the unit will be the secondary device on the IDE ribbon cable. Set the cover over the pair of pins next the pair from which you removed it, then press it until it completely covers the pins. The jumper is now in the slave setting position.
Mar 02, 2013 | E-Machines T2892 PC Desktop
How to set up jumpers when adding harddrive on master and slave
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Jumpers for a PC hard drive are next to the power connector. Mostly in between the power connector and the data cable connector. These are used for setting up Master/Slave settings and also to limit capacity of the HDD seen by PC BIOS on some older hard disks. Usually settings which are selected by jumper setting to various locations are printed on the hard disk information sticker.
hope this helps
May 14, 2011 | Dell Computers & Internet
. The drive is the Maxtor
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Apr 25, 2011 | Quantum Fireball Plus AS (QMP20000AS-A)...
WHICH IS WHICH? THEY ARE NOT MARKED, AND WHICH ONE DO I USE AS SLAVE OR MASTER WITH A NON SAMSUNG DRIVE?
which hard drive is if not a samsung so i can get the imformation from the net
hope this helps
Mar 26, 2011 | Computers & Internet
What are the jumper settings on the HD of DS, CS, PK AN Rsvd
Read more: http://wiki.answers.com/Q/How_do_you_determine_if_your_drive_is_set_as_a_slave_drive_or_a_master_drive#ixzz1GyDV7JxT
Mar 17, 2011 | Quantum Fireball Plus AS (QMP20000AS-A)...
I am installing an EPSON SD_600 5.25 inch flopy drive into a gateway computer. Which if any jumpers do I need to change into order to have this drive share a data ribbon cable with the existing 3.5 inch...
Unless floppy drive cables have changed in the past few years, they're designed for 2 floppy drives, with the jumpers on both set the same way. There's a small twist in the cable that changes the drive addresses instead.
Or you could just replace the existing drive with the new one.
Mar 13, 2011 | NEC Epson Combo 5.25 and 3.5 Floppy Drive...
How to replace SDRAM to DDR
sdram has two slots in the module where as ddr ram has only one and there are no jumper settings
Jul 30, 2010 | Mercury Electronics KOB 630e CFSFx...
System can't boot after performing a PC clean up by dissembling
beeps on start up is indication of missing hard drive. memories, or reversed IDE cable.
unplug all add-ons, leave just the memories and the monitor. turn on the machine. if all is good, then insert each items one at a time.
make sure the memories are the type that fits the machine (not physical but electrically).
I suspect your hard drive may be the problem.
go to BIOS and make sure all the items a checked and correct. specially the drive0 and drive1.
I assume that the hard drive is SATA. make sure the connection is 0 to 0 and 1 to1 in the BIOS.
check the hard drive in the BIOS, make sure it can detect the hard drive. if so, then the problem is in the hard drive. if you have another hard drive, try that one.
Dec 10, 2008 | Dell Precision 530 Minitower 2.4Ghz...
Epson SD-621L 1.2mb Internal Floppy Drive beige P/N: SD-621L - Epson Logo
173 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
