Question about Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player
Remote does not work, changed batteries still not working
Remote will not turn on or off. also will not raise the volme up or down
    Champion:
    Habit-Forming:
  • 239 Answers
If you have a camcorder turn on as if your going to record and watch for the infared beam when you point your remote at it.
Posted on Aug 09, 2014
What can I do to lower or raise the volume,,,,,,,,my remote not working to do so,,,,I changed the batteries, still nothing, stays at one level
make sure the batteries are known to be good. Make sure they are the right way round.
Take the remote to a television repairer for component testing.
Google
make model replacement remote
Mar 10, 2016 | Audio Players & Recorders
Changed battery in keyless remote and now doesn't start car or open doors
  • HOW TO - Change the battery and quick fix your car remote ...
    ? 9:32
    https://www.youtube.com/watch?v=KzCXGXCe0oc
    Sep 1, 2011 - Uploaded by tyreeztt
    Also if your remote isn't working with a new battery please check out this ... TO - Change the battery and quick fix your car remote / keyless entry ...
    Remote Key does not lock / unlock doors after battery change ...
    www.6speedonline.com/.../208274-remote-key-does-not-lock-unlock-do...
    Apr 17, 2010 - After I changed the battery, it would no longer lock / unlock the doors. ... I can start the call and all .. its just the door and trunk lock / unlock function that does not seem to work . ... now your fob is learned... the keyless entry goes into a "sleep" mode to preserve the batt.. if u do not use the ... Still don't work .
    how do i reprogram my lock remote to my car? i changed my ...
    www.cargurus.com > Questions > Hyundai > Tiburon
    CarGurusAug 17, 2009 - i change my battery an now my lock an un lock buttons dont work on my remote how o i reprogram it? ... I have a Hyundai 2003 Tiburon, and the followingworked for me, get ... However for a replacement keyless remote fob, you will have to go to ... And no, they don't do it for free (ranges from $30-$50 in my ...
    Top 5 Tips in Fixing a Keyless Remote ' eBay
    www.ebay.com > ... > Safety & Security > Keyless Entry Remote / Fob
    Key fobs that don't permit entry can be a major hassle for drivers, but fortunately, there... Drivers with a bit of basic electronics experience are often able to replace their ...After confirming that a remote is faulty, try replacing its battery. ... like "Jeep Wranglerkeyless remote," to find listings that will work with specific vehicles.
Jan 26, 2016 | 2005 Ford Freestyle
Volume button on tv doesnt work no remote
two choices, get the keyboard on the set repaired or get an original sharp remote which among remotes is not too expensive.
Dec 12, 2012 | Sharp 32U-S610 32" TV
How change farenheit to celcius, remote control unit model ar-rah2u
Turn off the remote, hold down the temp raise button until you see the F or C appear, hit the temp raise button again to select F or C, turn on the remote.
Mar 28, 2012 | Fujitsu Heating & Cooling
The remote is not working at all, example the lights not turning on and i even try'd changing the batteries still not working. What should i do.
mtousar
I would first check that the batteries (+) is all pointing down in the remote. If they are all pointing down, then you probably need a new remote. Call 1-800-333-3474, speak with Tech support to get another remote. I hope this helps.
Ray Calo
DISH Network
Feb 03, 2011 | DISH Network IR Remote Control
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Nov 18, 2009 | Televison & Video
No volume without holding remote button
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Sep 24, 2009 | Televison & Video
How can you tell if the remote sensor on a tv is broken?
First you need to check if your remote is working. You can use a digital camera to do so. First place new brand batteries in your remote and then look at the signal diode (the small transparent bulb thingy at the top of your remote). If you press the buttons on your remote you should see the diode flash. If not then there are one or more bad components on you printed circuit board or probably open circuits.
Aug 17, 2009 | Philips Magnavox Learning Universal Remote
Second remote not working correctly.
i put an extende piece of cable on my antena for second set raised it to same hieght as my tv in rear so ya dont see works great now
Mar 01, 2009 | DISH Network IR Remote Control
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player Logo
129 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
