Question about IBM Used Rational CCM102 10-Pan Electric Combi Oven/Steamer | Stock No. 11
Hi i got a rational oven and is show "error 34 -2-'' can you help
"error 34-2-"
What is error code 34 and where may i locate a troubleshooting guide?
Do you mean Check 34? Fault 34? Either of these indicates a problem with zone 34, which the location should be displayed by your keypad, such as Kitchen Glass, or something of that nature.
Jul 30, 2014 | Honeywell 6160PX Custom Alpha Prox Keypad
I have rational CM61 E ,display showing error E12, if know this anyone pl. share this
Hi, error 12 is displayed when the oven pcb is too hot, check that the air filter is clear and the cooling fan is running. Also it could just be the software, if it is an older oven and has the original software then it may just need upgrading by someone who knows what he/she is doing.
Jan 05, 2014 | Combi Ovens
There is a error code 34 35 in my kawasaki z750,2008.let me know the reason for that
Error Code # 34 - Exhaust butterfly valve actuator sensor malfunction, wiring open or short. Error Code # 35 - Immobilizer amplifier malfunction (Equipped Models) These are the exact error codes from the service manual itself. Good luck.
Sep 16, 2013 | kawasaki Z750 Motorcycles
Rational SCC 202 service 34-6
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
Jul 09, 2013 | Ovens
Rational combi oven
Any wires out the back that are loose?
Jul 04, 2013 | Kitchen Appliances - Others
I have one rational oven showing error 34
34 what there should be a no after 34 ie like 34-6,34-8 etc
Mar 22, 2012 | Ovens
Rational scc elec showing 34 -2 fault maybe on buss cable , which buss cable ,will show this fault code
hi . yes could be buss cable or more likely the fan blower motor , if light is flashing on motor pcb, carl (catering eng)
Feb 03, 2012 | Kitchen Appliances - Others
IBM Used Rational CCM102 10-Pan Electric Combi Oven/Steamer | Stock No. 11 Logo
391 people viewed this question
Top IBM Home Experts
john h
Tom Chichester
Are you an IBM Home Expert? Answer questions, earn points and help others
