Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
My dryer will not heat, but everything you have suggested has been tested and cannot find anything wrong. Is it possible to replace only the dryer?
Can the dryer only be replaced?
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Dryer doesn't heat...
Check the following to address this issue--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 04, 2009
DRYER NOT HEATING. Heat Element test good. No visible breaks. Tested the Thermal fuse it was bad so we replaced it. The dryer worked about 5 minutes. So we tested everything again and the Thermal Fuse and...
Somehow you are not getting enough air through the dryer to maintain a temperature below the thermal high temp cutout temp. or there is a control problem for the heating element so it may stay on the 5 minutes but like an oven the thermostat turns the element on and off. I hope you understand. There may be a relay that turns the element on and off, but the contacts have "frozen" or welded themselves together. If so that's your problem. Or there is another device with a similar problem. Unplug, trace the 220vac wires to controls and the heating element. Double check wiring. the Safety devices may be 110vac rated and 220vac is going through so won't hold the power flow. Hope this helps.
Mar 12, 2015 | Samsung DV209AEW Front Load Electric Dryer
Whirlpool Dryer IED4400SQ0 wont heat
Check your thermal fuse and the thermal cut-out fuse, two different fuses that can cause a dryer to run and not heat when open, or some dryers will not start when one of these has gotten too hot and opened....Usually caused by venting restriction of too much lint, common problem...........
A open operating thermostat or the high limit being open are also possible........;.
The other checks are live voltage checks, timer contacts, wiring, temp and internal motor switch......schematic is probably in back of control panel........
Takes some reading of a wiring diagram, understanding how to split the circuit ............Not for beginners.............Hope this helps...........do not forget to unplug dryer when doing anything on unit besides live voltage checks on circuits,,,,,,,,,,,,,,,
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
Not sure if this is my dryer but I have no heat. I replaced the heat sensor and also the fuse and still no heat. Took off the heating element and the repair store tested it and it was good. Not sure...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Kenmore 77632 Gas Dryer
My whirlpool duet electric dryer won't heat up. Everything else seems to be fine. My husband replaced the cutoff and thermostat. Any suggestions
heatman101
Dec 15, 2010 | Dryers
Dryer stopped heating...what to do?
Hello there
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Dec 08, 2010 | Dryers
My maytag electric dryer wont heat up
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
My dryer works but has no heat whats could be wrong
hello there
:please go through each of these steps that i have provided belw
investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
07fcef1.jpg Thermal Fuse
f9921fb.jpg Thermostat
17a0736.jpg Timer motor
Jan 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Wont heat up
Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
Jan 22, 2010 | Dryers
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
21 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
