Question about Altec Lansing Acs90 Computer Speakers - White - Acs 90
ACS90 on/off switch not working
No power
Driver side window stopped working
most of the time driver side windows switch be the first switch to wear out.try removing window switch work switch while moving the wires see if window try to go up, if yes, window switch broken.if switch not broken check see if power going to window motor when you work the switch you need a test light or digital volt meter to check to see if power going to power window motor.if power going to power window motor, either window binding or power window motor faulty. make sure driver side window master switch not locked out.if no make sure all the other power windows work if not you have blowed fuse.
Nov 26, 2012 | Hyundai XG350 Cars & Trucks
Power window problems
i have seen the ignition switch fail not turning on all the options check for power going to the switch
Sep 07, 2012 | 1999 Saturn SL
My ACS90 speakers have suddenly stopped functioning on my computer. They work perfectly when plugged into other devices, such as an ipod or a mp3 player, but when plugged into the computer, I keep o...
Hello
If you have its driver CD, install it into computer. There is no dirve for this device or the drive software in it has currupted. If you ar using Windows, windows will detect the drive automatically, if the CD is in the cd tray of computer. OK.
Jun 30, 2011 | Altec Lansing ACS 90 Computer Speakers
Acs90 Wire fixed to the speaker has a short, is there anyway to get the speaker open? I can splice wires if I can get to it...I think.
To get the speaker open you will have to get a long shaft #1 phillips
screw driver blade. You may have to order the blade from Amazon if
you can't find one locally.
Jan 12, 2011 | Altec Lansing ACS 90 Computer Speakers
There is no power coming in Switch from cable, i am putting a power cable in switch's power port but the switch is not working, and light are not working
Sounds like the power supply to the switch may be bad, if it doesn't turn the power on.
Check the voltage of the power supply with a multimeter to see what the transformer power supply is outputing.
Aug 02, 2010 | D-Link Computers & Internet
My right rear fog light does not work, any ideas why? the other lights work fine, and its not the light bulb
check for power at the light, if no power and fuse ok check for power to switch and power coming out of switch when switched on if there is power to switch but no power out from switch when switched on, switch is faulty, if there is power from switch, wire is broken between switch an fog light
May 27, 2010 | 2003 Porsche Boxster
Altec Lansing computer speakers
If you have a radioshack near you they have em, if not you can order it through their web page.
prs1c-2266271w345.jpg http://www.radioshack.com/search/index.jsp?sr=1&origkw=1%2F8+stereo&kw=1%2F8+stereo&kwCatId=&pg=2
Hope this helps
Mar 12, 2008 | Computers & Internet
Altec Lansing Acs90 Computer Speakers - White - Acs 90 Logo
41 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
