Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP tv component inputs not displaying colors properly
I have a Samsung DLP tv and while the HDMI works fine, the component inputs no longer work properly. Component input 1 does not work at all, and Component input 2 does not display colors properly. Blue colors appear as a teal-like color and actual greens wash out into a similar color.
This tv is out of warranty and I can't afford a new tv right .now.
snakehead
  • 1074 Answers
SOURCE: Reb bar in middle of screen when using component input
there is a problem with your ps2.have it check by a tech.good luck.
Posted on Aug 04, 2007
SOURCE: hdmi input
What are you attempting to use HDMI for? Sometimes you have to adjust the settings of the system that is using the HDMI connection. The tv needs to reset to HDMI
Posted on Apr 10, 2008
SOURCE: samsung dlp color issue
On the front of the DMD Board to the right of the fan is a sticker that says CN801. There is a small jumper there. Remove this after replacing the color wheel and it will fix the color issues.
Posted on Aug 18, 2008
welcomejee
  • 10594 Answers
SOURCE: DLP TV keeps flickering
Please recheck component connections in both units and make sure to hook up them according to corresponding colors like blue to blue, red to red and orange to orange.
Posted on Dec 13, 2008
Shuttle83
  • 1139 Answers
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
Posted on Jun 10, 2009
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
TV color changed to display green only
IF THE GREEN IS ON ALL INPUTS, THEN YOU WILL NEED A DIGITAL AND ANALOG BOARD REPLACEMENT, VERY EXPENSIVE REPAIR, TRY HDMI INPUTS FIRST, THEN COMPONENT AND SO ON
Dec 30, 2009 | Samsung HLT5089S Television
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
I have a samsung hdtv and the component 2 does not show the video in color...it only shows in black and white but in component 1 it is fine.if i use component 1 for dvd player it works fine with color and...
pls.set compnent 2 is on and set menu key on remot cantrol select system menu and see on display colour system is not proper . re set colour system is select AUTO and see the pictur is normal and ok.
Nov 10, 2009 | Samsung DLP HL-P5663W 56" TV
TV displays green colour on face, everything else fine
Was the color wheel replaced recently? If not and you are connected to a HD cable or satellite box using component cables. Make sure they are seated properly or connected correctly.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
Green tinted people
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Jul 18, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLR5067W goes from a normal picture to snowy green color
Greetings!
I hate to be the bearer of bad news, but it is not something that has a quick fix. Without inspecting it myself it is impossible to say, but the last three of these that I have seen have been bad digital boards and can be a real bear to change, even when you have experience.
I would get slightly different video symptoms when I would switch between the coaxial input to the component input to the HDMI input. But in all cases my on screen display and menu were anomally free. Hope this was helpful, even though I don't think it is something you should attack yourself.
Rob
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
"No Sync Signal" on both component inputs
Component ports can and do fail. You can get a replacement board from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2017 | Hitachi 50V720 Television
Samsung DLP HL-P5663W 56" TV Logo
284 people viewed this question
Jerry Greenberg
Jerry Greenberg
