Question about MPC Computers TransPort X1000 Notebook
Bios update locate download
Can not find emachine w3115 bios download
There's no reason to flash your BIOS they rarely add enhancements to BIOS's usually just bug fixes. Plus it's dangerous to flash it unless you know exactly what you are doing if you half flash something then it's toast flash is either all or nothing.
Dec 06, 2013 | eMachines W3115 PC Desktop
I upgraded my hp pavilion 9715nr notebook to windows 7 and need the bios and all the drivers for it
The BIOS, which stands for Basic Input-Output System, is the software that allows your operating system to work with your computer hardware. The BIOS software is stored on a separate chip that receives constant power from a small battery, called the CMOS battery. This battery allows the BIOS to process information, such as the system time, even when the computer is unplugged. HP releases updates for the BIOS on its Pavilion computers periodically, and it is important that you apply these updates to your computer to ensure a smoothly running system.
Restart the computer. Press the "F10" key when the HP logo appears on the screen. This is the hot key that allows you to access the BIOS. Locate the version of the BIOS installed on your system on the main BIOS screen. Press "F10" and select "Yes" to exit the BIOS. b> Upgrading Your BIOS b> Go to the HP Software and Drivers page in your Web browser. (See Below.) http://h10025.www1.hp.com/ewfrf/wc/static_software_select?swlinkmsg=100&lc=en&dlc=en&cc=us&docname=c01087277 Enter the model number of your Pavilion, which will be on the sticker containing the serial number, located on the bottom or rear of the computer, then press "Enter." Select the operating system that your notebook is currently running. Locate WinFlash for HP Notebook System BIOS in the BIOS section of the page. Verify that the version offered is later than the version currently installed on your Pavilion and download the file, using the "Download Only" option. Locate and double-click the file that was downloaded from the HP Software and Drivers page to begin the BIOS update. Follow the on-screen prompts to complete the installation.
also
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Jan 20, 2013 | HP Pavilion Computers & Internet
How to update medion ms-7502 Bios?
You download the BIOS update from here. In case you don't speak German, here's the translation:
  1. Download bios7502.exe
  2. Double-click the file and unzip (default is C:\Medion)
  3. Go to the location where you unzipped the files and run WinFlash.exe
  4. You can save you old bios (just in case) as i.e. oldbios.bin
  5. Now open the new bios version with the name W7502MLN.10R and start the update process by clicking the update button.
  6. Reboot and you're done.
Note: Don't run anything else when you're doing this and do not interrupt the process until the reboot is complete. You could risk rendering your BIOS unusable!
Feb 29, 2012 | Medion Computers & Internet
How to update my phoenix bios
First you will have to go to the manufacture's web site for the update program.
The firmware update (BIOS update) will be located in the same location as the driver downloads for your machine.
When you get to the site look for 'Support' and then 'Drivers and Downloads'. When you get to the page for your machine if there is a BIOS update available it will be located there. There may be more than one so look for the most recent.
Either your machine has a utility built in for upgrading your BIOS or else a program will be included with the download.
Instructions will vary with machines. Follow the instructions CAREFULLY! You must do this correctly or your machine may fail. In particular the upgrade process must not be INTERRUPTED!
This will be made clear in the instructions. The whole process only takes a few minutes though.
Hope this helps.
Jun 27, 2011 | Samsung Computers & Internet
Upgrade phoenix bios 4.0
Go to the website of the company who makes your laptop or desktop. The majority of these sites have a portion of their site they devote to updates. Look in this section to locate your BIOS updates. When you find the file you need, download the BIOS to your computer's hard drive.
Go to Biosman to download and install the Phoenix BIOS flash utility software. This software allows you to read the data your BIOS file contains.
Flash your BIOS via USB storage device. Copy your update to the USB drive. Then, modify the boot order of your laptop or desktop to begin with your USB drive. Push "F2" or whichever key prompts you to enter your BIOS when you reboot your system.
Double-click the BIOS file you just downloaded to run the upgrade procedure.
Good Luck
Jan 08, 2011 | Computers & Internet
Bios update
Go to the hp's website and search with terms "Your PC's Product Number+ BIOS Update" and you'll find out the available downloads related to your problem.
The package will include all the instructions and manual neccessary for updating your BIOS.
If you are having problems locating the downloads just send us your PC's product number and we'll send you the download link (if any available).
Here is a demonstration:
I searched with the terms "Compaq 5000 Desktop BIOS Update" and here is the result page
http://h20000.www2.hp.com/bizsupport/site/search/r4_0/jsp/search.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=96382&tx=Compaq%205000%20PC%20Desktop%20Bios%20Update
Jun 29, 2010 | Compaq Presario 5000 PC Desktop
Need to locate safe AMI BIOS update file for eTower 500is
you should restart and press F2 (on most pcs) to opent Setup. from there find the name and version of your bios. then go to your current bios providers website and download the flash update. it should be listed under the support tab. you may have to search. hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Sep 30, 2009 | E-Machines eMachines Desktop PC
Pc hang up at f2 after bios update
Try downgrading the BIOS to a previous version then load setup defaults. After that update it again with the latest BIOS version. If it does the same thing then the bios package that you downloaded could be corrupt, you may need to download it from a different location.
What is the model of your intel motherboard?
Thanks
C
Apr 03, 2009 | Intel Computers & Internet
Is there a bios update link ?
Here is the BIOS Link courtesy of HP:
WinFlash for HP Notebook System BIOS (for Notebooks with AMD Processors) - Microsoft Windows/Vista-Based
Click on that link and then click on the download only button. Save it to a location that you will remember and then after its done downloading, double-click on the file and it will update the BIOS for you.
Mar 01, 2009 | HP Pavilion dv6000z Notebook
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
Nov 06, 2008 | Computers & Internet
MPC Computers TransPort X1000 Notebook Logo
42 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
