Question about Sanyo CMH2472 Air Conditioner
I have a sanyo duted split and comes up with code ho2..
How do you fix the promblem..it says on the fault code...its compressor locked up..
  • johnpes Jun 20, 2009
    you are a looser
    i am a air conditioning technician in australia..not sure what you do..but you havent answered the question..
    Sergeant:
  • 340 Answers
Have a certified tec try to unstick compressor likely new compressor
Posted on Jun 20, 2009
  • 1 more comment
  • taa43 Jun 20, 2009
    Thanks what do you expect for free. you really think ya can get some thing fixed over the intern with out getting your self hurt I was looking out for YOUR SAFETY now who is the looser I've been doing this 28 years really call for service . or waste your time and probably money. regards
  • Etronix Jun 03, 2014
    Though this comment is quite old, a statement such as "have a certified tec try to unstick a compressor..." is a very inadequate response/solution.
    I believe ho2 error code is caused by a bad control board part 623-193-2134.
Error code ho6 means what
According to the sanyo site H06 is a Compressor Fault, Low Pressure trip. see: http://www.orionair.co.uk/Sanyo_fault_codes_air_conditioning.htm
These errors are difficult to diagnose. If you are technical, a good start would be (of course with the power disconnected) remove and reconnect all the connectors and cables on the control assembly board. Also make sure that the ground connections are tight. Good luck. And please let me know how you finally get this issue solved.
May 29, 2014 | Sanyo 24KS32A Cool Mini Split Air...
P0170 runs rough
code p0170 refers to fuel trim (FT) bank 1--malfunction===causes--intake leak---AIR system fuel pressure/pump/injectors--EVAP canister purge valve--HO2s
It also refers to heated oxygen sensor (HO2S) 3 bank 1--circuit malfunction===causes --wiring---HO2S--ECM
fix the o2 sensor and the purge valve and you may be on the way to fixing the faults.
Dec 26, 2013 | 1993 Suzuki Samurai
Hi have a jaguae x type with fault code p1647 changed the sensor with the grey plug and light has *** bk on can u please help
Fault Code:- P1647 Indicates a Power-train fault
The fault is generally due to a problem in the Computer & Output Circuit area
Fault Description: ECM HO2 Sensor control malfunction -bank 2 upstream (2/1)
Action of ECM:- ECM Default:- HO2S 2/1 control circuit inhibited
After clearing the DTC, complete the Drive vehicle for 10 minutes
Check for a reoccurrence of fault DTC.
Possible Fault:- HO2 Sensor 2/1 heater failure HO2 Sensor 2/1 sensing circuit: short circuit to ground, short circuit to high voltage, open circuit ECM Failure
Jun 15, 2011 | 2002 Jaguar X-Type
I have both a P1111 and P1646, what are these and how do you fix them
You can check out all fault codes at http://www.bluejag.co.uk
looks like faulty Lamda sensor.
Fault Code:- P1646 Indicates a Power-train fault
Fault Description: ECM HO2 Sensor control malfunction -bank 1 upstream (1/1)
Action of ECM:- ECM Default:- HO1S 1/1 control circuit inhibited
Possible Fault:- HO2 Sensor 1/1 heater failure HO2 Sensor 1/1 sensing circuit: short circuit to ground, short circuit to high voltage, open circuit ECM Failure
Jun 01, 2011 | 2003 Jaguar X-Type
My duted air conditioning started blowing hot air instead of cold and then stopped. blew a fuse and now will not work
Sounds as if the compressor has gone bad. The blowing of hot air and then the fuse blowing lets you know the compressor is pulling a lot of amps causing the fuse to blow and no cold air could mean the compressor is locked up and therefore you need a new compressor.
Dave
Jan 24, 2010 | Honeywell ER150B Air Conditioner
Compressor not turning on
is the compressor actually turning over ?? if not check the contactor, or capacitor is actually ok...
if it does turn over, are the stop valves open ??
Jun 16, 2009 | Sanyo Split System Air Conditioner
Three trouble codes
Trouble Code: P0421
Catalyst Efficiency Below Normal (Bank 1)
Possible Causes:
Air leaks at the exhaust manifold or in the exhaust pipes
Catalytic converter is contaminated, damaged or has failed
Front HO2S and/or the rear HO2S is loose in the mounting hole
Front HO2S older (aged) than the rear HO2S (HO2S is lazy)
Front HO2S or rear HO2S is contaminated with fuel or moisture
Trouble Code: P1173
HO2S-21 (Bank 2 Sensor 1) Circuit Malfunction
Possible Causes:
Base engine mechanical fault affecting one or more cylinders
EVAP Purge valve stuck or the hoses to the valve are reversed
Fuel metering fault (fuel injector sticking open or leaking)
Fuel pressure too low or too high, fuel supply contaminated
HO2S element is contaminated or the HO2S heater has failed
PCV system has air leaks at the valve or related hoses
Trouble Code: P0174
Adaptive Fuel Trim Too Lean (Bank 2)
Possible Causes:
Vehicle driven low on fuel or until it ran out of fuel
One or more injectors restricted or pressure regulator has failed
Fuel delivery system supplying too much or too little fuel during cruise or idle periods (e.g., faulty fuel pump, or dirty fuel filter)
Air leaks after the MAF sensor, or air leaks in the PCV system
Air leaks at the EGR gasket, or at the EGR valve diaphragm
Exhaust leaks before or near where the front HO2S is mounted
HO2S is contaminated, deteriorated or it has failed
Fuel control sensor is out of calibration (i.e., ECT, IAT or MAP)
Base engine -mechanical- fault affecting one or more cylinders
May 18, 2009 | 2001 Mazda MPV
Heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Sep 30, 2008 | Sanyo 24KS62R Cool Mini Split Air...
GEARBOX DIAGNOSTIC CODES FOR FORD MONDEO AUTO 2002
all eobd codes starting with p zero have standard meanings irespective of model or make
PO12 CODE CAMSHAFT POSITION (cmp) intake/front,bank 1 timing over ******
possible cause valve timing engine macanical fault cmp acutator
POO36 CODE HEATED OXGEN SENSOR HO2S)2BANK 1, HEATER
CAUSE FAULTY SENSOR WIREING SHORTING TO EARTH EC
PO59 HEATED OXGEN SENSOR (HO2S) BANK 2, HEATER RESISTANCE
WIREING HO2S
THESE FAULT CODES HAVE BEEN OBTAINED FROM AN AUTO DATA DISC
I HOPE THIS IS OF SOME HELP TRY CLEARING THE CODES AND SEE IF THEY RE APEAR
IF THEY DO THE SENSORS AND WIRING NEED CHECKING
Aug 22, 2008 | 2001 Ford Focus
Sanyo CMH2472 Air Conditioner Logo
123 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
