Question about Amana Refrigerators
Amana ta18tl Not getting cold defrost cycle maybe
Need schematic Amana frig SQD25VW-P1314202WW
Hello Ron Carlson
Page 6 of 6...
Pretty straight forward refrigerator!
Although I agree with the first answer you got from Todd Marr...a lot of available volunteers here have been around a lot of blocks...
Can call out the Whirlpool & Frigidaire units you share parts with... and how to very cheaply you can
test various parts to bring you to your very quick victory...
I'm just saying, ice-maker, defrost issues, warm refrigerator side... Fast frost build-up... puddles?
If you'll pardon the pun ...
FROST FREE REFIGERATOR/FREEZERS are pretty cool...!
Amana SCD25TBW Technical Information Wiring Diagram
Apr 06, 2016 | Amana Refrigerators
Fridge side is not cold and freezer side ice building up on the back panel fan is working is it the thermistor causing that and how many ohm's thermistor should have
Defrost heater is open and needs to be replaced. Or maybe the defrost timer is no good along with defrost thermostat.
Check them out.
Nov 25, 2015 | Amana Refrigerators
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
My Amana refridgerator keeps defrosting on it's own. when the water and ice work it works perfect but when they quit the refridgerator is defrosting
ck for a faulty defrost teminator ( amana fans will not work till they reset at a freezing tempt and if it does not reset the freezer gets cold but the fan does not blow the cold ofer to the fresh food area . the the defrost cycle takes over and this goes on and on . and the mild goes bad . so try a terminator . . if fan motor is bad it would also cause this prob .. mm
Aug 18, 2010 | Refrigerators
Top refrigerator warm bottom is ice cold.
An automatic defrost time turns the defrost cycle on and off every 24 hours. If problem continues, problem is most likely defective defrost timer.
Even electronically controlled units often have electro-mechanical timers for defrost cycle.
Jun 15, 2010 | Amana ABB1927DE Bottom Freezer...
Hi i just replaced my evap fan in my amana mod bbi20tpsw i have 120 v at the motor leads until i hook up the motor then the voltage drops to 9 v
Replace the defrost thermostat , not the motor . The defrost thermostat ( bimetal ) sends power to the fan motor when bimetal is cold ( 35 degrees maybe ) . When first plugged in , the compressor cools the coils until the bimetal clicks on . Then the fan comes on , blowing cold air into the fridge . If the fan came on when first plugged in , it would blow warm air , gradually getting colder . Amana is the only brand using this process of coolant .
Sep 02, 2009 | Amana Refrigerators
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Refrigerators Logo
22 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
