Question about Philips Satinelle HP6409 Epilator
I have a problem
After i plugged my conair epilator for 16 hres i unpluged it and it does not work without the cord
I have an epilator (Remington Model # EP-6025). I have been using it in US and now, I would like to use it in India. Can I just use an adoptor for the chord and use this epilator
Yes, India uses 230 Volts at 50 Hz alternating current as the power source. Plugs and sockets have either grounded earthed 3 Pin connections (Type D) or ungrounded 2 pin connections (Type C).
All you need is an adaptor like the one in the picture.
Dec 27, 2014 | Remington Ep6025 Epilator
Emjoi light caress epilator jammed
The major reason that epilator shavers stop working is because of hair that is caught inside the machine. If you have taken the top off and cleaned it out thoroughly using the brush, then this likely isn't the cause.
Is it still under warranty? if so, i suggest that you contact the manufacturer and ask where you can send it for fixing. if your warranty has run out, you can still ask the manufacturer for a list of approved repair shops.
Feb 26, 2013 | Emjoi Light Caress Gold Corded Epilator,...
Conair Ion 1875 hair dryer won't go on
did u try pressing the trouble shooter on the cord if that dosent work
take it back
Dec 05, 2012 | Conair Health & Beauty
Plugged in india without transformer
Probably will cost more to repair than replace.
Aug 21, 2017 | Braun 5270 Epilator
Can you supply a replacement 13 V, ac/dc adapter (HP5230, HP 6414/16/24)?
Bernabeu, we do not supply anything at fixya except information. I will ad links to where you can purchase a power supply. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Power TM 6 6ft Long Cable AC ADAPTER Philips Norelco Satinelle Electric...
Amazon com UpBright AC Adapter Charger For Philips Satinelle Soft Epilator...
NEW AC Power Adapter Charger For Philips Satinelle Epilator HP6400 HP6401...
Results for Epilator philips charger
Jan 24, 2011 | Philips Satinelle HP6409 Epilator
Need manual for Conair Corded phone Model SW3414wcs
You should be able to get another Manual from the Conair Website and Download in PDF Form.
Jan 04, 2009 | Conair TAD920 Corded Phone
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
Flashing message light
Insert a new 9 Volt battery (machine will work without a battery if you want to ignore the blinking light)
Apr 27, 2008 | Conair TAD2018CG Digital Answering Machine
Philips Satinelle HP6409 Epilator Logo
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
