Question about GE G.e. Gtwn4950lws He Top Load Washer
What does gl mean
How to fix gl code
How do I fix error code E000 on a canon MF8180c Laserbase
hello the error E000 MEANS "fixing assembly faulty start-up (open circuit in the main thermistor)
You need to Check the connector of the fixing film unit or Replace the fixing film unit or Replace the DCNT Borad PCB.
you need to get the service manual for it will help you a lot you can get it from the below link:
http://goo.gl/uYxA40
good luck
Aug 05, 2013 | Canon MF8180C Color Laser MFC Printer
Is it okay to drive my 2001 Hyundai Accent GL with a damaged and possibly broken front cv joint?
Amber,I wouldn't drive, could be unsafe to you and the longer you drive the more damage it will get means more money.
Jan 07, 2013 | Cars & Trucks
Where is the purge system on 2003 hyundai accent GL
Code 133 is a problem with the O2 sensor in front of the catalytic converter not switching back and forth between rich and lean.
Code 144 is for a high voltage problem with the third O2 sensor which I doubt your car has. If that is the actual code it may mean something else for your model.
The sensors would need to be checked out with a scanner.
Sep 23, 2012 | Hyundai Accent Cars & Trucks
I have a GL tv i need the code
I am guessing you mean LG tv..
Try this tv remote code: 0056
Feb 04, 2012 | Televison & Video
1984 subaru gl turns over will not run, it's getting fuel and spark also two solenoids make a constant clicking noise with ignition turned on. Ecs light on reading code 33. what is it and how do I fix...
Hello! A code 33 means "main system in feedback" this isn't really a trouble it is saying that you have the test connectors plugged together...And the ECU is in a test loop...Check the OBDI connectors and get back to me ...Saailer
Nov 27, 2011 | Subaru GL Cars & Trucks
Service engine soon intrigue gl 2001
SERVICE ENGINE means that fluid and filter must to be replaced under periodical maintenance.
CHECK ENGINE its a warning about some fault code stored in the PCM (computer). Need an scanner reader tool to know which code is there.
Good luck.
Oct 09, 2011 | 2002 Oldsmobile Intrigue
I hvae ford contour 1996 GL , when I drived by high road , o/d lamp on the panel get flash, I don't know what that means, can you help me what that mean? thank you
It probably means there a problem with your torque converter and tcclutch, or maybe a faulty wiring issue to the trans. obtain an obd2 scanner (at a local auto parts store) and download the codes from your car while its on. this will generally tell you what you need to know. you can find obd2 code charts all over the internet.
May 03, 2011 | Ford Contour Cars & Trucks
What is an F1 error code on a 2003 Honda Gold Wing GL 1,800
FI stands for Fuel Injection. The fuel system sensors have detected a problem. It could be anything > a dirty air filter restricting airflow, a plugged injector, an error in fuel mapping, any number of things. Serious problems can trigger the computer to prevent the engine from starting until the problem is fixed. You will need to take the bike to a dealer to have them plug in a code reader. The code reader will tell you exactly what problem has been detected. There is a chance the sensor has gone bad. Keep that in mind. Now determine if you want to do the fix or have the dealer do it. Please rate my answer.
Aug 31, 2010 | 2003 Honda GL 1800 Gold Wing
Volvo 940 gl reg j93 has 1992
i had the same problem with my 1994 940 volvo
i called a dealership in town and asked nicley,gave them the vin and they looked up the code and told me. online im not sure where to look it up, but if you call its a chep fix
Jan 13, 2010 | 1994 Volvo 940
My check engine light on my 2001 hyundai accent gl reads code po441, po442. What does these codes mean?
Most of the time they mean:
p0441 = Evaporative Emission System Incorrect Purge Flow
p0422 =
Evaporative Emission Control System Leak Detected (small leak)
MOre info at http://www.obd-codes.com/p0442
Jan 10, 2010 | 2001 Hyundai Accent
GE G.e. Gtwn4950lws He Top Load Washer Logo
13 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
