Question about Home
Fix uberhaus boya shower doors
Need new hardware
The grey cartridge (diverter valve) of my shower is discontinued. The whole copper piece costs over $100. The piece I need only costs about $20. Any suggestions if I can find this anywhere else?
Replace Shower valve - how much $? - RedFlagDeals.com Forums
forums.redflagdeals.com > Home & Garden
Nov 27, 2011 - Hi all Just bought a new shower column from Rona. ... the valving is in the pressure balance valve, thermostatic valve, diverter valve or volume ...
How To Troubleshoot A Thermostatic Shower Valve ...
? 9:45
https://www.youtube.com/watch?v=2pVuvG6q84A
Aug 10, 2011 - Uploaded by bathstore
This video shows you how to troubleshoot and rectify thermostatic control problems and the on/off control for a ...
Shower Systems & Valves - Home Depot
Jan 01, 2016 | Home
Where can i find parts for my shower door
Go to nearest home depot. They can help yo.
Oct 12, 2015 | Home
I installed a uberhaus tub and shower faucet luna series and I don't have the instructions the water won't shut off when I turn the handle to off
you might have the cartridge turned 180 degrees out of alignment. remove the handle, and carefully rotate the stem until the water shuts off, then re install the handle in its appropriate position.
Mar 26, 2015 | Home
Need driver for
It is not your computer that needs drivers, it is the hardware you need to connect to the operating system that needs a driver. From Windows 7 and up, Microsoft only allows drivers, if the manufacturer asked for certification and the hardware and driver and they work conform Microsofts demands. If the hardware and driver is certified the driver is also on the Microsoft website. Most of the time if you use new hardware the operating system goes to Microsoft to see if there is a correct driver and then installs the driver.
For older hardware, only few manufactures make drivers and ask certification. Most only develop drivers for their new hardware. So for older hardware there are only a few drivers. If Microsoft can't deliver drivers, or the manufacturer from the hardware can't, you are lost. The devices won't work with the new operating system. Nobody told you that before upgrading. Since I upgraded to win 7 I could not use several expensive things I was used to, like a great Logitec webcam in a sphere, a great sound card from Creative labs, with break out box and so on.
Jul 28, 2014 | HP DeskJet 3520 InkJet Printer
Driver whiz registration codeF9C3AEFF
It is not your computer that needs drivers, it is the hardware you need to connect to the operating system that needs a driver. From Windows 7 and up, Microsoft only allows drivers, if the manufacturer asked for certification and the hardware and driver work conform Microsofts demands. If the hardware and driver is certified the driver is also on the Microsoft website. Most of the time if you use new hardware the operating system goes to Microsoft to see if there is a correct driver and then installs the driver.
The only chance you have is on Canon USA. This site gives enormous support.
Success
Jul 27, 2014 | Canon Cameras
Acer monitor 185w80ps
Jul 25, 2014 | Acer Computers & Internet
Driver for my VGN FS30B for portable devices
Jul 11, 2014 | Sony VAIO VGNFS Series VGNFS30B VGNFS31B...
I need drivers for laptop model w76s
It is not your laptop that needs drivers, it is the hardware you need to connect to the operating system that needs a driver. From Windows 7 and up, Microsoft only allows drivers, if the manufacturer asked for certification. If the hardware and driver is certified it is also on the Microsoft website. Most of the time if you use new hardware the operating system goes to Microsoft to see if there is a correct driver and then installs the driver.
Jul 09, 2014 | Computers & Internet
Door strip missing
Hi I think you need doorsweep which you can find at: CRL lawrence co.They have a wide range of products to fix your problem.
I hope that helps.
Jan 24, 2014 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Computor wont recognize dvd player
You might need to have a computer administrator account to perform some tasks.
Most new devices your computer will recognise automatically. When your comp is running, plug in your new dvd player. Does it beep and say 'New Hardware added? If not then use
The Add Hardware Wizard which enables you to add new hardware or troubleshoot any hardware-related problems.
Open the Add Hardware Wizard
  • To open the Add Hardware Wizard, click Start, click Control Panel, and then click Printers and Other Hardware. Under See Also, click Add Hardware.
  • If it can't recognise the player, it gives you the option to select the correct make and model. Is yours on the list? If not, you may need to go to the Microsoft site and update the list of players.
  • Do come back here if you need further help.
Dec 28, 2013 | Televison & Video
Home Logo
44 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
