Magnavox 46me313v wii hookup?
I cannot hook up my Wii to my new 46" Magnavox tv no matter what I do? The red and white inputs are there under HDMI 1, but the Wii still will not work there. I'm sitting here scratching my head because I absolutely cannot figure it out. Anyone else who had a similar issue and fixed it?
  • 3,320 Answers
Red and white inputs are for audio.
Use yellow, or get the proper cable if you don't have it.
Posted on Mar 31, 2014
SOURCE: TV connections- Wii, Direct Tv and DVD palyer
Hidden switch for output coonections on back panel of dvd player.
Posted on Dec 29, 2008
Shuttle83
  • 1139 Answers
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
Posted on Jun 10, 2009
vinnyq
  • 157 Answers
SOURCE: My wii connection is black and white
You are connecting it into the wrong input. The Wii comes with a RCA cables that should go into the Video (composite) input that has yellow, red, and white. The component input will not work with the RCA cable input. Plug your Wii into Video1 and you should get the right colors. There should be another HDMI on the side of your TV, there are inputs located both on the back and side of the TV for your convience.
Posted on Oct 10, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: have a Samsung led hdtv 46
The Blu-ray players need a firmware update, otherwise some new disc may not play.
Posted on Apr 28, 2010
SOURCE: LCD TV Wii only displays black and white - no colour no sound
it works fine on a regular tv
Posted on Nov 03, 2011
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
How to hook up wii to a magnavox 32mf301b
You can connect the composite (Red white yellow) cables to corresponding connections on the back of the television. Then set channel to corresponding video input.
Oct 19, 2012 | Nintendo Wii Console
Wii in black and white
Picture Is Black and White or Does Not Appear Situation:
  • The console powers on and shows a black and white image on the television screen
  • The console powers on and there is no image on the television
What to do:
  • Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
  • AV Cables
    • Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
    • Try another set of inputs on the TV, or hooking the Wii console up to another TV.
    • If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
  • Component Cables
    • Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
  • If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Apr 17, 2012 | Nintendo Wii Console
Why cant i get my wii console to work in color
Well it might either be the tv or the av cables that is causing the wii system to be in black grey and white then.
What to do:
  • AV Cables
  • Component Cables
Still Not Resolved:
Mar 06, 2012 | Nintendo Wii Console
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
How do I hook up my Wii Console to my new Emerson
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
Dec 22, 2009 | Nintendo Wii Console
I have a samsung led tv and am trying to hook up a wii. The tv does not have component video - only hdmi and usb. How do I hook this up?
I've never heard of a TV not having component cables (the 5 plug cables: red, blue and green video cables, red and white audio cables). I've seen some newer ones without composite (3 cables: yellow video, red and white audio), but never component.
I find is hard to believe it has no component. I looked at some Samsung LED tv's this weekend, and although they lacked composite, they had component. Are you sure you mean component?
The Wii only comes with composite video cables, so you'll need to buy a component video cable for the Wii to hook it up if your TV has no composite inputs.
Component Cables for the Wii
TV's have inputs on the side and rear. If the TV truly has HDMI, USB and nothing else (which I find hard to believe), then you'll need a cheap home theather 5.1 receiver. Ifyou get a cheap one with HDMI out, it should have a few composite inputs on the backside. A cheap sony one can be had for sub $200. If you hook the Wii into the receiver via composite, and the receiver into the TV via HDMI, it will allow you to hook up and play the Wii (and it may upconvert it too, depending on the receiver).
Nov 23, 2009 | Nintendo Wii Console
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
Top Televison & Video Experts
