Question about Keurig Platinum B70 Coffee Maker
How to install the water filter on a keurig
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
It just presses straight down.
Posted on Sep 28, 2014
My Keurig only brews a part cup
Most likely you need to change the filter and descale it as well.
I use a CleanCup once a month:
https://www.amazon.com/CleanCup-Single-Machine-Cleaning-Capsules/dp/B00E0QAS34/ref=sr_1_1?ie=UTF8&qid=1480095410&sr=8-1&keywords=keurig+cleaner+cup
I change the filter once every 3 months:
http://www.keurig.com/Accessories/6-Pack-Keurig%C2%AE-Water-Filter-Cartridge-Refills/p/Water-Filter-Cartridges
And I descale it every time I change the filter using this:
http://www.keurig.com/Accessories/Keurig%C2%AE-Descaling-Solution/p/Keurig-Descaling-Solution
Otherwise, the tubing is going to get clogged up in your machine and produce smaller and smaller cups of coffee, not to mention, when you keep your machine clean, your coffee will always taste its best!
Hope this helps!
Nov 25, 2016 | Keurig Coffee Makers & Espresso Machines
How do I order a filter for my Keurig?
You must be more specific about "filter".
Are you inquiring about the "My K Cup" reusable wire mesh filter to use your own ground coffee? You can order them online through Amazon. Here's a link:
http://www.amazon.com/Keurig-K-Cup-Replacement-Coffee-Filter/dp/B009VIUI04/ref=sr_1_6?s=home-garden&ie=UTF8&qid=1442776181&sr=1-6&keywords=Keurig+filter
If you're asking about Keurig charcoal water filters, here's a link for that on Amazon:
http://www.amazon.com/Charcoal-Water-Filters-Replaces-Keurig/dp/B00HL2ZR2Q/ref=sr_1_6?ie=UTF8&qid=1417372516&sr=8-6&keywords=keurig+filter
Hope this helps. Thank you for using Fixya!
Sep 20, 2015 | Coffee Makers & Espresso Machines
Need source for replacement water filters
Nov 30, 2014 | Keurig Coffee Makers & Espresso Machines
My Keurig says to prime
This video link below, from keurig, should get you back running.
remove reservoir, if you have a water filter, remove it and set aside. Use a damp non abrasive cloth and clean tank including filter screen. DO NOT DRY the inside with a cloth as lint may remain. DO NOT PUT in a dishwasher. Let it air dry. Reinsert the water filter. Put tank back into unit making sure it is aligned properly. Fill tank all the way up with clean water. Turn power on and attempt 3 WATER only brew cycles at the 6 or 8 ounce size. DO NOT USE A PORTION PACK.
If this doesn't work, you may have to clean the needles of the K-cup holder and / or the filter screen and water reservoir port.
If the problem persists you can contact you can contact Keurig at 1-866-901-BREW (2739) or Keurig.com
http://www.keurig.com/what-if-brewer-indicates-prime?cm_mmc=Google-_-Dynamic%20Search-_-Keurig-_-Keurig%20Homepage
Mar 09, 2014 | Coffee Makers & Espresso Machines
Keurig sounds funny when it's drawing water, like it's internals are moving in slow motion . what can I do to fix this ? This Keurig is only 8 months old !!
There should be a charcoal filter in the water tank. This filter doesn't come with the machine so a lot of ppl do not know it is supposed to be there. If it keeps "priming" the filter needs to be changed.
Aug 24, 2013 | Keurig B50 Coffee Maker
Our keurig powers but doesn't filter water through it or heats up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 21, 2011 | Keurig Elite B40 Coffee Maker
We recently obtained a used B70 coffee pot from my mother-in-law. There is a charcoal filter, but I am not sure where to put it. It is in some kind of holder that has 1 through 12 on it. Do I just drop...
Keurig has the manuals for their coffee makers here: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The B70 is their Platinum Brewing system. The direct link to the manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/DD2E19AE632A45BDAA55D72706420B74.ashx .
You need to put the filter into the reservoir at an angle (caddy-corner to the reservoir). According to user comments, it works best going from the front left corner and back to the right. Others find they need to wet the filter for 30 minutes and then squeeze out some of the excess water to loosen the filter. This site has comments on using the filter with the Keurig brewers: http://www.keurig.com/accessories/water-filter-starter-kit .
I hope this helps.
Jul 19, 2011 | Keurig B70 Coffee Maker
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
How do I change the water filter ?
how do you change the keurig water filter?
May 19, 2010 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
