Question about Miller Welding Tools
Need new cable
Repair
Iwas wanting to know if i can repair the shift cable myself instead of buying a new one?.... cable just snapped and gear shifter just went limp.. please help.
unless the adjuster fell of then you cannot repair the cable
if it snapped then it was need of a replacement one anyway
Apr 20, 2015 | Cars & Trucks
The sound coming from my right bose on-ear headphones
i think ur headphone wires or its pin at end will be defective..
99%there is no chance of failures in speakers ..
try to replace ur headphone cable with new cable.
just solder the cable with speaker inline pins..
May 25, 2010 | Bose On-Ear Headphones
I NEED A NEW POWER CABLE
Please note if you cable is faulty. Meaning not powering your unit up KODAK will exchange the cable free of charge if the frame is covered under warranty.
If not you will need to purchace a new cable: Either online or by calling the service centre:
contact KODAK in order to arrange a repair or order a new cable. Remember your cable is covered under the same warranty as your frame, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 14, 2010 | Kodak EasyShare EX1011 Digital Picture...
Cable to power window appears to be off the pully. How does it go back on? The driver's window went all the way down. Will not stay up. Cable appears to be dangling. How is it routed back to the pully. I...
that is a cable driven window regulator and when the cable comes un done then it is broke and un repairable. you will need to swap it for a new one. very common issue with this style regulator and is a sealed system with no repair unless you real get into it. but the regulator are not that much and make no sense to try to repair a broken one. hope you make out okay and good luck.
if you have any more question please ask.
Nov 21, 2009 | 2002 Dodge Durango
I need to know how to properly install a new park brake cable on a 1995 f150 st.six 4.9efi. I got the new cables and installed them but the new front and intermediate cables won't reach the bracket holding...
The adjustment would be on the cable themselves. They should be full extended before inserting them. For a free full online repair manual for your truck, go to autozone.com, register for free and view your repair manual
Jul 21, 2009 | 1995 Ford F150 Styleside Regular Cab
No picture just sound.
If a red ring flashed, it means you're probably going to need a repair. Judging from the problem, though, it was probably a 4 red light error. You might need some new cables for it. You can get some for around $5 at several stores. If new cables don't work, call 1-800-469-9269 or go to support.xbox.com, then file a new repair. It will be free to get it fixed, because they extended the warranty on all consoles by 3 years (starting in 2007).
Jul 07, 2009 | Microsoft Xbox 360 Pro System Console
Bad USB Port in Camera
With that amount of non-accidental damage, a replacement is the best option financially
Mar 05, 2017 | HP E427 Digital Camera
I think you CAN--there's a lovely site with specific instructions,,,, Do It Yourself Camera Repair --- for fabulous step by step instructions WITH pictures & simple explanations that a novice can follow!!!
In short, all you need to do is find another USB port (even from a broken camera or other device) to replace yours. It seems that you'll need to solder it in -? - that's the step I'm trying to research right now--I'd like to just glue mine back in because I don't know how to solder--- but the tricky part is getting the camera apart, not touching the flash capacitator nor any of it's power-holding chips, and not damaging any of the other components.
(ACF0EB8F)
Aug 18, 2008 | Kodak EasyShare DX7440 Digital Camera
Welding Tools Logo
59 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
