Question about SwingSmart Golf Swing Analyzer
Will not turn on after charging
When I charge my swingsmart the ligt blinks green then goes out. When I unplug it nothing happens no ligts nothing
Jazzy wheelchair scooter 1450. Why does it go crazy with flashing (charging lights)?
Hi Emilee,
The lights flashing crazy, may mean you have locked out joystick. to unlock, try first, turn on joystick and push horn button twice right away. if that did not work, try turn on and push lever forward all the way wait until it beeps, then back all the way until it beeps again. that should do it. If not then count how many lights are blinking and how many times it blinks. consult owners manual trouble shooting guide for answer, or call 800-800-8586 Jazzy tech
Mar 12, 2016 | Health & Beauty
Changing ligt bulbin morphy richards 23L
Probably not that hard but you do have to take the cover off and do not go near the heating element as it is charged with electricity. Of course unplug before you do anything.
Dec 11, 2014 | Morphy Richards Microwave Ovens
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
Grenn ligt blinking will not work
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 12, 2014 | Element ELC-HS321 32 in. LCD TV
D61W20 61 in. Rear Projection Television: turn on tv ligt blinks 3 times and goes out....
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Apr 28, 2010 | Televison & Video
Mitsubiushi wd52525 nstatys ligts keeps blinking green. Lost power when the TV was on and now i have a status light that just keeps blinking green.
Unplug for a minute, when pluged back in light should blink for a few then go out, should be able to power on after that!
Dec 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony DSC H7 Access lamp always on
the battery is not in good condition.you need to charge the battery adequeately and also check the green ligt in the charger when you plug in.
Oct 22, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Sonykv-32v40 red ligt blinking black screen and soud good
Take it to a shop... It's a good bet that the jungel Ic, crt driver Ic or something in the HV has failed. Could be also that the crt itself is failing. If that's the case a tech can test it with a B&K and know for certain.
Also, if you want to save a few dollars take it in to them, don't make them come and get it - it just drives the price up for a pu/del charge.
Bill
Nov 24, 2007 | Sony KV-32S45 32" TV
SwingSmart Golf Swing Analyzer Logo
453 people viewed this question
Top SwingSmart Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you a SwingSmart Golf Expert? Answer questions, earn points and help others
