Question about SanDisk 4GB microSD High Capacity Memory Card
Format tablet corrupted partitions via adb - SanDisk 4GB microSD High Capacity Memory Card
I can not reset my tablet to factory reset no matter how many times it will not work
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website;
www.adbdriver.com/downloads/
or click on link below for direct download.
ADB Driver Installer (9.22 MB)
next, install the ADB driver then you will see a USB root on notification area on your PC.
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-0.jpg next, download the fastboot click on link below;
https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-2.jpg next, command prompt will open and you need to type these commands;
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-5.jpg This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
that is all; your tablet will be completely restored...
thanks and good luck.
Jan 26, 2016 | Supersonic SC-91JB 9-inch Android 4.1...
How to hard reset my supersonic tablet
www.adbdriver.com/downloads/or click on link below for direct download.
ADB Driver Installer (9.22 MB)next, install the ADB driver then you will see a USB root on notification area on your PC.
No comment next, download the fastboot click on link below;
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
Jul 03, 2014 | Supersonic 7" Touch Screen MID Tablet
Tablet
Setup android in recovery mode and select load from adb.
You need to install the Android debug bridge toolkit SDK on the pc and have the right drivers for the tablet.
You may also have to alter the android ini file in your profile to match the dev id in system device manager.
Its not an easy thing to do especially on chinese no name tablets.
Then issue the command Adb sideload "filename.zip"
Apr 22, 2014 | Hipstreet Tablets & eReaders
Kocaso m1066 bricked
Try reloading the firmware via a PC and ADB connection via USB.
This will overcome the brick!
Here is the instructions from the manufacturer
Support Firmware
Apr 08, 2014 | Kocaso M1066 Android 4.1 Dual Cameras 8GB...
Restart a tablet when it is locked
  • Connect the tablet with USB cable to the PC
  • Open the command prompt
  • Change directory to the android SDK platform tools (Type in cmd--> cd C:\Program Files\Android\android-sdk\platform-tools)
Type following commands in cmd
  • adb devices (verify device is identified by pc. If not reconnect device and try again)
  • adb shell
  • adb reboot
It will restart.
Feb 12, 2014 | Android 4.0 Tablet PC
Sanei a76 tablet more pattern lock attempt. how to remove unlock my tab please help.
Here is the trick to unlock your Sanei 76 tablet pattern and Gmail :
1) Download Android SDK and install Drivers
2) Open ADB in Command Promt (cmd)
eg : my adb file is stored in this directory
c:\android sdk\sdk\platform-tools\
so to open adb inside this director i use the command
cd c:\android sdk\sdk\platform-tools\
7ac56502-9b5e-40ad-a42e-02deb0a64701.png 071aa9ed-d87b-43b7-aaf9-a53a9c9c27c3.png
3)type the command adb devices to check wether your device/tablet is connected to your PC
(if your device is connected you will get some thing like this : 727ab014-596a-4066-9df4-dbb8eb522e6a.png
4) Then type the command adb shell.
you will get some like shown below
5)if you got symbol rounded in the above screen shot download this file and run it.(if your device is not rooted)
http://downloads.ziddu.com/download/23715300/root.rar.html
6)The type su in adb shell
you will get super user privilages
7)Then type the command below
wipe data
8)the type command reboot
9)Now you are done you are successfully removed your Gmail and Pattern lock.
Oct 06, 2013 | Tablets & eReaders
Dead Acer iconia a500
Attempt to remove the drive and see if the notebook boots to bios. This may remove a problem where the drive has gone bad, if that does not work out at least then you know one more step. If the unit does nothing, check your battery to see if it's still charged....
Past that step look for the worst, sorry
Feb 11, 2013 | Acer Iconia A50010S16u Tablet Computer
I have the MiTraveler 7D-1A Bought for the grandkids and they locked the screen . Now they cant ge back in. Need help unlocking the tablet. Please help
on the back of the unit there is a small hole that says "reset"....gently push a straight pin or anything that will fit in the hole. that resets the tablet.
Dec 24, 2012 | Tablets & eReaders
Forgot pattern need to unlock
If you've already set up a Google Account on your tablet:
1. Try entering unlock patterns several times right in a row. It *should* ask you to enter your Google Account info as an alternative way of letting you in, after which you can turn off pattern locking or set a new pattern.
2. If you set up a Google Account and the tablet isn't asking you for that info you can try to unlock it from this page:
https://www.google.com/accounts/DisplayUnlockCaptcha (this might only work on hardware authorized by Google, I'm not sure)
Keep reading for more details.
3. BUTTONS! There is usually some combination of button presses on boot that can get you into a "reset" or "safe mode" where you can reset it. It varies from tablet to tablet, however. For example, on my Haipad M701-R when I flip the on/off switch off and then on, short press the "end/sleep/power" button and immediately press and hold the "Menu" button through the boot process I go into "Safe Mode."
Also, some APAD tablets have a small, unmarked hole on the side of them that you can stick a paper clip into and press a soft-reset button. No idea if that clears an unlock pattern though.
4. If those options don't work, or if you have not set up a Google Account (either because you bypassed it or you have a tablet without official Google apps on it) another option is to use ADB (Android Debug Bridge) to unlock it. Go to Google and download the Android SDK (if you haven't already) and install it. If you're on Windows you'll also need the USB drivers.
1. Plug the tablet into the computer via USB and turn it on/boot it up.
2. Open a Terminal/Console and change directories to your Android SDK /tools/ folder.
3. Enter ADB commands. On Windows these will be "adb.exe" and on Mac/Linux "./adb" - I'll just use "adb" below for simplicity:
Code:> adb devices
This will let you know if ADB can "see" and "talk to" the tablet. If you don't get any devices reported back check the USB cable, drivers (on Windows), and that the tablet didn't shut down on you. I should warn you, however, if the tablet didn't have "USB Debugging" turned on, this will not work. Assuming it reported back finding a device proceed:
Code:> adb -d shell # sqlite3 data/data/com.android.providers.settings/databases/settings.db sqlite> update system set value=0 where name='lock_pattern_autolock'; sqlite> .exit # exit > adb reboot
If all went well the tablet should now boot WITHOUT the pattern lock enabled!
It will probably ask you for account info again like the first time it was booted. You can bypass that by pressing in all four corners in sequence upper left, upper right, lower right, lower left (if I recall correctly). Once into the tablet perform an actual factory data reset or it will pester you for setup info EVERY time you boot it. Go to Privacy>Factory Data Reset>Reset
5. Last resort is to reflash the tablet. Without knowing SPECIFICALLY which tablet model you have, though, there's no way anyone could tell you how to flash it or where to get compatible firmware. Assuming you DO know what you have and where to get a compatible rom for it, check elsewhere on the forums for instructions on how to flash your specific tablet with that firmware. Once it is flashed the "drive" is wiped and reset so you'll have to
go through the "first run" setup again, but at least it won't have a pattern lock on it.
Jan 16, 2012 | Archos 70 Internet Tablet
SanDisk 4GB microSD High Capacity Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
