Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Can not change channels with remote
I have a 26” Sharp LCD TV. Suddenly I can no longer change channels with the remote although the volume and on/off still work with the remote. I can change channels with the buttons on the TV. Tried the remote from another Sharp TV I’ve got and have the same results, can turn on/off, change volume but can not change channels. Any ideas?
  • ernie_lombar Jun 15, 2009
    Forgot to mention, the TV has a cablecard installed.
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
MrScary66613
  • 1990 Answers
SOURCE: my sharp tv model 20H-S60 remote input button is not functioning.
Welcome to Fixya! First thing would be to Disassemble the Remote and Clean the Pads and Terminals. Inspect the Board for Breaks in the Circuits. These can be fixed Easily with Solder or Even the Contact Pen that Radio Shack Sells. You can Draw the Circuit Back on the Board with it.
Posted on Jan 10, 2009
SOURCE: 52 INCH sharp aquos lcd REMOTE NOT WORKING
Make sure your remote lock is set to off.
Posted on Apr 22, 2009
dsacco86
  • 1077 Answers
SOURCE: Cannot control TV with remote after DTV change
Cool. It's good that you fixed your problem.
Just in case that it happens again, your TV come with a "RESET" and "SYSTEM RESET" button on the back of the TV. 90% of the time, the SYSTEM RESET button will solve the problem.
Posted on Jun 13, 2009
satavlad
  • 405 Answers
SOURCE: no input selection availiable on sharp aquos lcd tv
You have to come back to EZ SETUP and complete the setup procedure. Press MENU>SETUP>EZ SETUP.
Posted on Dec 29, 2009
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
I have a sharp 52". the remote will adjust the volume but, i can't change the channel. Help? Out of nowhere I could no longer change the channel. The Mrs is getting tired of standing next to the tv so I...
Sometimes, if certain remote control keys are used over and over again the rubber on the bottom of the buttons wears off onto the inside contacts, breaking the electrical connection. This is common on power and channel keys, especially. If you can get the remote opened up, you can clean the contacts with a cloth and it might help. Otherwise, it may be worth buying a universal remote. Good luck! Der Strom
Apr 05, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
564 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
