Question about Photography
Pandigital cord what size cord does the pan7056 use?
What size line and how to rewind spool
Depends on the engine size of the machine, small electric machines take 1.5mm cord, small petrol engine machines have 2.0mm, medium size machines have 2.4mm large machines have 3.0 mm and 3.5mm cord
Sep 06, 2011 | Garden
Yes, I have a Craftsman 25 cc Gas Trimmer and we just snapped the starter cord. Do you have to open up the head to fix this? Does it need a special type of cord?
Yes you have to remove the plastic recoil assembly and install a certain size cord. We use a #3 or 3.5 cord on all our string trimmers, blowers with that size engine.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
HAVE A TRANSFER SWITCH IN MY HOME TO PLUG A PORTABLE GENERATOR TO. PROBLEM IS WORKED GREAT BUT WAS ON OTHER SIDE OF HOUSE. I HAD A 4' CORD BUT BOUGHT A 80' CORD TO PLUG INTO THE TRANSFER SWITCH NOW WHEN...
Hello, what you are not telling us is the size of the wires in the 4' cord and the 80' cord. However, you are correct in your thinking that the longer cord is cutting back on the available power that you have. Yes, if you extend the length, then the wire size in the cord has to be increased as well. To give you a size we will need to know the generator size. Having said that, an 80' cord is going to be a BIG amount of money. You might want to tell yourself how much money you are saving pulling the generator around. If you have to use the generator a lot, you might consider installing a cable to run the generator with.
joe
Feb 22, 2011 | Honda Electrical Supplies
WHAT SIZE EXTENSION CORD FOR GA7021 SHOULD I USE AND MAX LENGHT? BURNING UP GRINDERS
Well for 15A the minimum wire size in your cord should 14 gauge, Length can't really be specified but you want to go for less resistance in the cord, thicker wire and less length will give you less resistance (more so thickness). If your grinder works fine without the extension cord, I would recommend getting a heavy duty extension cord with 12 gauge wire and trying that.
May 25, 2010 | Makita Angle Grinder 7" 6600 Rpm, 15 Amp
Hammer on Makita model 6905H corded impact wrench 1/2 size broke.
go to web site there is a parts list for your model and order the part
May 01, 2010 | Makita 1/2" Corded Impact Wrench
What is the right size trimming cord for the st 155
On the spool you should be able to find the size. Look for decimal sizes; .065, .080. etc... That will be the correct size...Lee
Apr 01, 2010 | Homelite Mighty Lite Lawn Trimmer
What kind of extension cord to use?
You should use a cord with the ground wire in it. If you're running a heater and the wire is getting hot, it's not whether it should be an indoor or outdoor cord it's the wire size that's the problem.
If you wire is getting hot you need a larger wire size.
Depending on the amps of the heater rule of thumb
15 amps a minimum of 14 gauge with ground
20 amps a minimum of 12 gauge with ground
30 amps a minmum of 10 gauge with ground
If you are using a cord over 15 to 20 feet then you may want to go to a larger wire size.
You will know if the wire size is correct if you let the heater run for a while 20 to 30 minutes and then feel the wire it should just barely feel warm it shouldn't get real warm or hot.
Dec 28, 2009 | Vornado REH1-0001-01 VortexHeat Compact...
What size rip cord do i need?
Rip electrical cord has a smooth side and a rib side. which one is wire to the load side of the lamp?
Dec 20, 2009 | Electronics - Others
What size usb cord do I need for my panasonic pv-gs29 mini dv
In camera not all USB cord have the same size but mostly of the camera USB cord have 2.0 or 2.5 size.
Oct 04, 2009 | Panasonic PV-GS29 Mini DV Digital...
Need to buy starter pull cord --- size??
take your cord with you and get something similar in size
Jul 22, 2009 | Garden
Photography Logo
24 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
