Question about Garden
Where is timming mark on camshaft
4 hp
c17hydro
  • 2984 Answers
SOURCE: 2002 kia spectra timming belt digram needed to
  1. Disconnect battery negative cable.
  2. Remove power steering and air conditioning compressor drive belt by loosening power steering fasteners.
  3. Remove generator bolts and generator belt.
  4. Remove water pump pulley.
  5. Remove crankshaft pulley and timing belt guide plate.
  6. Remove upper/lower timing belt covers.
  7. Turn crankshaft clockwise until "I" mark on intake camshaft pulley and "E" mark on exhaust camshaft pulley align with marks on cylinder head cover.
Posted on Aug 29, 2009
alicantecoli
  • 22326 Answers
SOURCE: 2002 Hyundai Acent 1.5 sohc,need info on cam timming
didnt you mark it before you removed the old belt??
Posted on Nov 01, 2009
  • 740 Answers
SOURCE: i need to know where the timming marks
THGERE MAY NOT BE ANY MARKS
Posted on Jan 08, 2010
  • 1757 Answers
SOURCE: isuzu trooper 2002 RLV engine. camshaft timing
Sorry for the severe delay.
I am personally going back to answer your unanswered question.
I do not know if you still need the answer, but I am going to answer it in case you still do.
Click on the following direct Link. It has the Timing Belt Diagrams and Photos with Marks for the Camshaft and Crankshaft that you will need. It also has numerous other helpful diagrams, instructions and photo's for use.
Again my apologies...
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2002/make/isuzu/model/trooper/2002_isuzu_trooper_timing_belt_diagram_marks.htm
Posted on Mar 25, 2010
perkins48
  • 14406 Answers
SOURCE: how to set both cams back in place with timming lined up
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c15280092505 Here you are.
Posted on Aug 07, 2012
Need help with timming on camshaft timming on a artic cat prowler utv
There should be dot marks on the gears which line up with marks on the case,or you can Google your request,and a video will show you how it's done.
Sep 28, 2016 | ATVs
Wht are the toyota timing marks
ON THE CAMSHAFT GEAR ARE UNE HOLE NEED TO MATCH THE HOLE WHIT THE MARK A THE CYLINDER HEAD AND ON THE CRANCSHAFT GEAR ARE UNE DOT ALING WHIT THE MARK A THE ENGINE OIL PUMP COVER
Sep 01, 2014 | 1992 Toyota Camry V6
4jx1 camshaft marks on isuzu trooper 2001 3,0 dohc engine
the timming gear that the belt runs on has a mark (V cut in gear) to rear cover at about 12 o clock and crank pulley has timming mark for top dead centre, both cams have cut outs in rear that a special tool (camshaft stopper 5-8840-2592-0) locks into to hold cams in correct position, but can do without this, if the cam belt gear is off, the keyway should be at 12 o clock. the marks in the camshaft gears (dots) is for assembly of sissor gears to solid gears on camshafts that run together and they should match up only if you had this appart.
stevenhurc_12.jpg no.1 is timming mark
stevenhurc_13.jpgthis is the locking plate tool
Apr 19, 2011 | 2001 Isuzu Trooper
2001 chev cavalier timming chain diagram
Timing Chain and Gears REMOVAL & INSTALLATION 2.2L Engine Fig. 1: The timing marks on the sprockets should be in alignment. If not, turn the crankshaft until the marks are aligned 91113p63.jpg
Fig. 2: The timing chain tensioner is retained by a Torx head bolt (1) and a regular hex head bolt (2) 91113p58.jpg
Fig. 3: Unfasten the camshaft sprocket bolt 91113p59.jpg
Fig. 4: Remove the camshaft sprocket and the timing chain at the same time . . . 91113p60.jpg
Fig. 5: . . . then remove the tensioner assembly 91113p61.jpg
Fig. 6: Compress the tensioner spring and insert a cotter pin or nail in the hole provided to hold the tensioner in position 91113p62.jpg
  1. Disconnect the negative battery cable.
  2. Remove the front cover as previously detailed.
  3. Place the No. 1 piston at TDC of the compression stroke so that the marks on the camshaft and crankshaft sprockets are in alignment (see illustration).
  4. Loosen the timing chain tensioner nut as far as possible without actually removing it.
  5. Remove the camshaft sprocket bolts and remove the sprocket and chain together. If the sprocket does not slide from the camshaft easily, a light blow with a soft mallet at the lower edge of the sprocket will dislodge it.
  6. Using a suitable gear puller, remove the crankshaft sprocket. To install:
  7. Press the crankshaft sprocket back onto the crankshaft.
  8. Install the timing chain over the camshaft sprocket and then around the crankshaft sprocket. Make sure that the marks on the two sprockets are in alignment (see illustration). Lubricate the thrust surface with Molykote® or its equivalent.
  9. Align the dowel in the camshaft with the dowel hole in the sprocket and then install the sprocket onto the camshaft. Use the mounting bolts to draw the sprocket onto the camshaft and then tighten to 66-68 ft. lbs. (91-95 Nm).
  10. Lubricate the timing chain with clean engine oil. Tighten the chain tensioner.
  11. Installation of the remaining components is in the reverse order of removal. Fig. 7: Exploded view of the timing chain and sprockets - 2.2L OHV engine 87953107.gif
Nov 11, 2010 | Chevrolet Cavalier Cars & Trucks
Diagram for timming belt on 2002 ford focus 2.0ltr
there isnt marks!the cam pulleys have do nothing with timing!remove the valve cover and see in the other end of the camshafts and find two eccentric cuts!turn the crankshaft to the top dead point on the cylinder 1 the two cuts must be in the same line on the upper or lower side.you need aspecial tool to lock the camshafts and another to lock the crankshaft!this is the timing procedure!now you can change anything you want!note!the cam pulleys are conejointed to the camshafts!no marks no pins no safe pins etc.isnt difficult but complicated simple!
Jan 23, 2010 | 2002 Ford SVT Focus
Nov 01, 2009 | 2002 Hyundai Accent
I need a new timming belt on a 01 kia sephia how do i change it
Below are the procedures to remove the timing belt...
1. Disconnect negative battery cable.
2. Loosen power steering lock bolts and nuts accordingly and remove tension from power steering (P/S) and/or air conditioning (A/C) compressor drive belt. 3. Remove P/S and/or A/C drive belt.
4. Loosen generator mounting bolts and adjusting bolt. 5. Remove generator bolts.
6. Remove water pump pulley.
7. Remove crankshaft pulley and timing belt guide plate.
8. Remove upper and lower timing belt covers.
9. Turn crankshaft so that timing mark on timing belt pulley is aligned with timing mark on engine.
10. Check that "I" mark on intake camshaft pulley is aligned with mark on cylinder head cover and "E" mark on exhaust camshaft pulley is aligned with mark on cylinder head cover.
Do not move camshaft or crankshaft once timing marks have been correctly positioned.
11. Loosen tensioner pulley lock bolt.
12. Protect timing belt with a rag.
13. Remove tensioner pulley.
14. Remove timing belt.
Regards,
Jeep Brainy
Sep 20, 2009 | 2001 Kia Sephia
2002 kia spectra timming belt digram needed to verify timming marks. Dual overhead camshaft.
Aug 29, 2009 | 2002 Kia Spectra
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
