Question about Remington Sports Remington 12 Ga 87011001187 Shotgun Cap Sling Mount
Bolt is sticking due to the stock hitting the ground and getting brnt
The rod that holds the stock is bent and do the two little guides fit into that rod.
    Problem Solver:
  • 18 Answers
Take the stock off
Posted on Jan 06, 2015
    Sergeant:
  • 213 Answers
Dear A,
Here is a Blueprint of the 1100 Series to help you render a decision. http://www.gun-parts.com/remingtonshotgun/Aug15_02.jpg
Here is a Blueprint of an 870. http://www.gunpartscorp.com/pub/schematic/Remington_870_schem.jpg
Another source is to go to the FAL files and present the question to the Armorers and Professionals who support the community. Here is the link.
870 Failure To Feed The FAL Files
Kuhnhausen has a great gunsmithing book the covers the Remington 870, 11-87 and 1100. You will see this in the remarks at the FAL site.
Fare. Well.
Posted on Dec 10, 2014
The tub hits the wall of washer during spin cycle an a suspension rod will come off at the top, it has four suspension rods.
There are plastic cups that the rods set in are they all in place and you have little springs that come from the rod to the tub top. The rods could also be bent causing the tub to hit the wall.Hope this helps!
Jul 27, 2015 | Washing Machines
Deadbolt becomes stuck without a lot of force.
This sounds like the fit between the thumbturn and the bolt is compromised. If you pull out the thumbturn, take a look at the flat metal blade that fits into the rectangular or "8" shaped hole in the deadbolt mechanism. I think this has become bent or misshapped somehow. Or maybe the hole has a rough burr on it. You might be able to flatten the blade with a hammer and anvil or maybe dress up the problem with a file. Good luck.
Dec 04, 2012 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
My JDL120 MOWER DECK WON'T RAISE OFF THE GROUND MORE THAN 1.5".iHAVE HIT ROOTS AND ROCKS OVER THE YEARS AND WAS STILL ABLE TO RAISE DECK NORMALLY.
First thing is to get down and look at the linkages. You may have a weld that came loose, or a nut that worked it's way off. You may also have something that bent.
Does the lever move all the way up but the deck doesn't move with it, or does the lever stick at the low level.
If it's sticking, you may just have picked up an obstruction like a stick or stone in the wrong place. You may also have a bent or damaged linkage.
Does one side or just the front or back lift up? One of the pins that hold the bars that it pivots on may have come off or broken as well. Looking underneath while someone works the lever for you can tell you a lot.
Sep 21, 2012 | Garden
I have a constant vibration when running my poulan pro self propelled 22 inch cut lawn mower. any solutions to the problem......
My guess is that you have hit something pretty solid while mowing. You have either bent the blade, bent the crankshaft, or both. To check for a bent crankshaft, set the mower up on a table or tailgate where the handle is on the ground and the spark plug is pointed into the air. DISCONNECT THE SPARK PLUG !!! You don't want to risk starting it in this position. While a friend holds the engine brake lever closed, and pulls the rope, you need to watch the blade bolt. If the bolt spins without wobbling, just replace the blade. If the bolt wobbles, then the crankshaft is bent. A bent crankshaft can be straightened by a reputable shop. Not all shops are will to straighten crankshafts. It is not a cheap repair.
Aug 23, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Remove motor from generator
aramature must be removed to get to the mounting plate it will slide out off case loosen long bolt in center of armature hold armature and hit bolt briskley will pop off be careful putting arm back may be 2 brushes inside have a helper hold brushes back
Jul 30, 2010 | Briggs & Stratton Briggs and Stratton...
How to repaire inner tie rod bushings
you need to get it out.
get on the engine and go to the back at the fire wall
look for the bolt that hold the tie rod
there should be a lock washer which is bent to keep the bolt in place
bend down the tab so you can put a wrench on the bolt
loose the bolt then loose the outter tie rod
take the rod out and repair or replace
Mar 04, 2010 | 1999 Dodge Intrepid
How do you install a timing belt tensior on 1997 Mazda Millenia a used one?
You have to take it off the engine and press the rod back into the housing. Use a press or a c clamp. There are alignment holes near the top of the tensioner. Find a piece of steel that will fit through the holes. I used a very small allen wrench. Press the rod until the holes on the side of the tensioner and the hole near the top of the rod align. Insert the piece of steel through the holes. Keep in mind that you will need to take the piece of steel out so make sure there is enough sticking out to pull with pliers or wire cutters(dont cut the steel) You can get to it easier if its sticking out of the hole facing the water pump or out of the front. Release the c clamp or press. Bolt it back up. If you bolt the top bolt first(not too tight) you can move the tensioner around better to get the rod under the pulley lever better. Then put in the lower bolt. Tighten. Then pull out the piece of steel used to hold the rod down.
Did that help you?
Nov 13, 2009 | 1999 Mazda Millenia
Briggs motor bent one push rod
This is a vary commom problem with an Intek engine, I have a similar 21HP engine with similar issue. The valve is sticking in the valve guide, the valve guide usually slides in or out. If out, the guide can jamb against the keepers and not allow full valve opening, thus bending the rod. Fix the loose guide and tight valve before you put in another rod, or you will soon be putting more rods in. I think B&S should help everyone on this one. If the guide goes in, it can cause the valve not to close fully and cause a no run condition.
Sep 14, 2009 | Briggs & Stratton Briggs Stratton Intek V...
1997 ply voy, replaced trans and now engine misses.
Check the gap of the crankshaft position sensor. You can buy a stick-on button for it at a Chrysler dealer or just eyeball it and get close. The sticker attaches to the end of the sensor, when you install it you push it all the way down to touch the tone ring and tighten the bolt. When you hit the key to start, it scrapes the sticker off and you have the correct gap. Or you can loosen it, push it all the way down and then lift it up about one millimeter or so. I hope this helps.
May 23, 2009 | 1997 Plymouth Voyager
Remington Sports Remington 12 Ga 87011001187 Shotgun Cap Sling Mount Logo
800 people viewed this question
Top Remington Sports Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Bill Boyd
Are you a Remington Sports Rock and Ice Climbing Expert? Answer questions, earn points and help others
