Question about Goodman CKL36AR36 Air Conditioner
What size capacitor does my ck361a need?
I am fairly sure the capacitor is blown, but I need the mfd and volts, also where can I find an "exploded" view of my unit?
    Sergeant:
  • 340 Answers
Capacitor for what compressor, motor? if motor its on the data plate
Posted on Jun 19, 2009
How can I find comfotmaker maybe 1987 cannot find serial # NEED CAPACITOR MFD & VOLTS
If you need new capacitor you have to buy capacitor MFD and VOLTS same old capacitor.no need serian and anything.
Jul 15, 2014 | Heating & Cooling
Behringer xenyx 1222fx mixer capasitor
check the capacitor and its value and type. i havent see the equipment but knows about capacitors etc
it usually comes in values like 0.01 2.0022 and so on and higher value like 1 mfd to couple of thousand mfd.you shouls use the same value and the voltage for the replacement one has to be same or more in voltage since higher voltage is no harm but lower voltage will explode or burn in electrical appliances it is used as filters to block spark in the carbon or starting capacitor thich helps to run the motor if it is built to run with a starting capacitor like the one used in water pumps or electrical ceiling fans.
Aug 29, 2012 | Cars & Trucks
What start capacitor is used on the Trane XE1100 air conditioner
There is NO START capacitor on your unit. There is a RUN capacitor and one place said it is a 30 mfd / 5 mfd at 440 volt. These are an oil filled capacitor with both a 5 mfd section for the fan and a 30 mfd forthe compressor. Find a part number on it and search Ebay... that is where I got mine..
Aug 02, 2012 | Heating & Cooling
Sm26 needs a capacitor what is mfd rating
Normally a capacitor of rating 8-10 mfd /450 volt can be siufficient for the single phase motor and since you have not mentioned the capacity it is ideal to check on the old one after cleaning the dirt off with soap and water or with diesel oil. A hum on the motor will confirm that the capacitor is faulty and if the capacitor on applying direct AC( 230) does not pick up charge then it is faulty.
Jun 06, 2012 | Seaga Manufacturing SM26 Commercial...
My goodman unit wants to start and the contactor is not engaged
Could be the run capacitor is bad. Usually they bulge at the top where the connections are, but sometimes they are bad but appear to be fine physically. You would need a multimeter that reads microfarads to see if yours if good.
Below is a link to the part in question. Yours should be rated at 50/5 mfd, 370 or 440 volts.
50/5 MFD 440 Volt Round Dual Run Capacitor
May 22, 2012 | Goodman CKL42AR42 Air Conditioner
Have a ck36-1b goodman ac unit need to replace dual run capacitor i have nothing to tell me volts or mfd. any place to find spec for unit?
you need a 5/45 x 370 volt mfd capacitor. I just installed one in the same type of AC today. 5 mfd is for the fan moter and 45 mfd is for the compressor, the 370 is the voltage.
Sep 14, 2011 | Heating & Cooling
LED blinks in milli seconds and the images appear too late.
If your lcd comes with ac adapter open this and check for blown or bulge capacitors, replace this with same value.
If your monitor comes with plug cable, open your monitor (too risky to do it by yourself) check the power supply section, check and replace blown and bulge caps.
Jul 09, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Does a gemtech 40 + 5 mfd work with a comfortair
Hi, as long as the 40uf x 440 volts and 5uf x 440 volt capacitor are the same is what you are replacing, yes it will work. Don't replace this 40 uf x 440 volt with a 40 uf x 370 volt cap. Voltage and microfarads must be the same, brand name makes no difference or these numbers, only the uf and voltage. Must be a 40 uf x5 uf, 440 volt dual run cap. It will work if the unit you want to put it on calls for that cap. The comfortair is a 3 ton unit, just be sure it takes a 40x5x440 volt and it will be fine.
Shastalaker7
Jun 04, 2010 | Heating & Cooling
My lcd monitos blinks random intervals
If that model has no external power supply then the supply is internal and some capacitors are failing. The problem will worsen until the display will not work at all. It's a fairly common problem with that type of monitor. The capacitors are cheap, and not too difficult to desolder and replace. The hardest part sometimes is getting the darned thing open. I had just recently went through this process with an AL1917. Seems like there were four 470 mfd/25 volt and two 220 mfd/25volt. Be sure to use the hi-temp type caps (105 deg C)
Hope this helps.
Dec 16, 2009 | Acer AL1916W 19" LCD Monitor
Goodman CKL36AR36 Air Conditioner Logo
455 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
