Question about Holmes Products Holmes Digital Thermometer And Hygrometer
Reset imx6 droidbox
Need to reset to factory setting because i need to set up 3d launcher
I cant get in y phone. all it says is launcher stopped working. what can I do
Reboot. Remove battery and wait for 5 seconds. Put it back on. Enter 'Recovery Mode'. There will be some hardware button combination to enter Recovery Mode like Power+Volume Up+Volume Down. After entering, depending on your phone, you might have to navigate through physical buttons.
You will find 'Clear Cache' and 'Clear Dalvik Cache'. Do both.
And then Reboot normally. Now see if you can get the launcher working on your phone.
If that doesn't work, press home key, see if you can open some browser application or Play Store and download and install a new Launcher.
If that doesn't work, but you can somehow access settings, go to settings->Apps and clear data of your Launcher App.
If that isn't possible then, go to Recover Mode again and do 'Reset Factory Defaults'. This should make your phone feel just like when you brought it.
May 19, 2016 | ZTE Warp
Launcher is missing
Launcher is Missing is it a luncher app you downloaded from the playstore or is it the default launcher of your phone because if its just an app that you downloaded from the playstore its missing because a factory reset will erase all your data and apps
If its the dufault launcher is your phone rooted?
Did you perhaps uninstall the default launcher using a root tool like link to SD?
If you have uninstalled your default launcher then you would have to flash a stock rom from your phone's manufacturer or download a custom rom from the internet
Sep 03, 2015 | Nextbook Premium 8 Se Android
When i turn it on i get a message that says unfortunately,launcher has stoped wont let me do anything else
You need to do a FULL reset.
1. Power off unit
2. Hold down POWER and Vol - (or Vol+ if Vol - doesn't work) until Android reset screen appears.
3. Scroll down to factory reset and select it.
4. Agree to reset
Unit will reset itself and start over like it was brand new and you will lose everything that was installed. Most likely you have a corrupt operating system and this may help. However, many android apps will not work on that tablet as its an older tablet that does not have an upgraded OS available.
Good luck
May 25, 2015 | Ematic 7" Touch Screen Tablet
How to reset samsung PN51D550 3D plasma to factory default settings
Call Samsung, they helped me do it while on my cell with them.
Jun 07, 2014 | Samsung PN51D550 51 3D HDTV Plasma TV
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
My Sungale ID706WTA tablet is crashing. Every time I power on the tablet the error notification keeps popping up saying the Launcher has unexpectedly stopped. I have to keep hitting force close a billion...
Factory Data reset / Hard reset
  • Switch off the tablet.
  • Press and hold the Power and the Volume Up keys.
  • When you see the logo, release only the Power key. ...
  • From the Android recovery menu select one by one:
  • - wipe data/factory reset.
  • - Yes -- delete all user data.
  • - reboot system now.
Nov 22, 2017 | Sungale ID706WTA Tablet
I bought it from my cousin my internet got cut off so i had it cut back on and nnow i dont no the security code to use it
There should be a small button on the router, Sometimes labeled "reset". It's often red/orange and you may need a paper clip to press it. Push the button while the router is plugged in and it will reset the router to factory defaults.
After, that when logging in, just click submit as the router has no password from the factory.
Source:
"http://en-us-support.belkin.com/app/answers/detail/a_id/48/session/L2F2LzEvdGltZS8xMzA0MzE1Nzc5L3NpZC81NVF4OFdzaw%3D%3D"
And the source about the password
"http://en-us-support.belkin.com/app/answers/detail/a_id/30/~/setting-the-router%27s-administrator-password"
May 02, 2011 | Belkin Wireless Surf Router (F7D2301)
Hi, I bought Smart Epad 7" I had error of The
You can restore your epad to factory settings by going to the settings menu > privacy > Factory data reset. and then your epad should be running normally again.
Mar 04, 2011 | Tablets & eReaders
How to install themes to samsung galaxy 551 phone
you can download
1.GO launcher
2.ADW launcher
3.Launcher Pro
4.Regina 3D launcher
5.Panda Launcher
6.Honeycomb Launcher
7.Home Launcher
from Market and install it
and within any launcher you will get many theme
and also you can customise them
Try it
Feb 19, 2011 | Computers & Internet
Holmes Products Holmes Digital Thermometer And Hygrometer Logo
97 people viewed this question
Top Holmes Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Holmes Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
