Question about La Crosse Radio Controlled Atomic Clock
Set a new time
Solar time change
Solar lights won’t come on new umbrella. Turned the red switch on at the end of umbrella, and nothing.
Check first for any disconnect wiring --connect, 2nd test the actual light if its good or busted (defective)---change it same value. If its real new some Solar lights has a protective seal on its power sourse contact---remove it first.
May 08, 2018 | Solar Electrical Supplies
How do I change time zones?
denver to montana HUMMMM thought they were same time zone if not only 1 hr different
Feb 23, 2015 | CASIO, INC. Casio Protrek PRG270-1 Solar...
How do I insert the green and red pins into a timer, they keep falling off
What timer do you have?
What is a solar?
Add a comment and describe timer in detail.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
http://waterheatertimer.org/How-to-set-timers.html
Some timers have integral trippers that are not removed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 24, 2012 | Hardware & Accessories
I cant change the time on my sportline solar watch 8105 help
Press "MODE" and above it "SET" and it should help you re-set the time correctly.Hope this helps!
Mar 07, 2011 | Sportline 1000 Memory watch
Just bought this watch via ebay. How does one change the time?
mcdevito75 here, Simply place your finger nail under the crown (winder) lift it up gently to the set position then turn the crown to set the time.
Jun 16, 2010 | Seiko Pulsar Solar 4000 Watch
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Casio g-shock mtg-900 gets ERR when trying to set atomic time
Did you go to Casio and download the manual? I just did after my battery change and I hoping it updates tonight at 2,3, or 5am with my watch in the window.
Oct 29, 2008 | Casio Atomic-Solar MTG900 Watch
Casio sport STR-900 watch
How to set the solar power time change, my watch has remained with the same time; and not one hour ahead (spring forward) ?
Sep 04, 2007 | Casio Watches
Konica Minolta Dimage x1 solarizes all pictures so that they appear as negatives
Send it back - obviously didn't do a good job on this one. They will give you another Don't mess with it.
Jun 21, 2007 | Konica Minolta DiMAGE X1 Digital Camera
La Crosse Radio Controlled Atomic Clock Logo
23 people viewed this question
Top La Crosse Home Experts
David Burbee
David Burbee
Are you a La Crosse Home Expert? Answer questions, earn points and help others
