Question about Vizio E472VL 47 LCD HDTV - 1080p, 1920 x 1080, 5ms, 120Hz, 100000:1, V
Vizio will not power on, vizio emblem is off.
My 47inch vizio went out after a power surge. The tv would not turn back on when using the remote and also when using the remote. I opened the back, nothing smelled burn. I plug the power cable after I opened it, it turned back on. I closed the cover and it would not turn back on. After a few tries, I closed the back and the tv worked for a few weeks until I turned the breakers off because I was working on electrical in the house. The tv would not turn back on. I did the same thing, opened the back and it turned on once and that was it. It never turned back on again, the vizio emblem never turn orange when plugged. I ordered the power board first because it was cheaper ($47), still nothing. I ordered the main board ($119) and still nothing. The emblem still does not work. Help.
    Genius:
  • Vizio Master
  • 1,039 Answers
Did you check the power cord of intermittent connection.
Posted on May 13, 2014
3 Suggested Answers
  • 5 Answers
SOURCE: Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Posted on Jan 25, 2010
taran_2005
  • 10515 Answers
SOURCE: I purchased 47" vizio and
I am sorry to hear regarding the trouble. To eliminate bad surge protector, kindly plug the TV directly into the socket.If problem still persists, then it would confirm an internal failure and needs repair. Unfortunately, there is no small fix for the same. If you have electronics repair experience and would be able to perform the repair, revert and i would be able to follow up.This is most probably an issue with power supply board. Bad caps often cause the same problem. Do provide with the model number so that i could tell you the components that needs to be tested and replaced,if find faulty.
Thanks and Regards
taran_2005
Posted on Jun 15, 2011
No power on Vizio VO47LF 47inch
power supply board faulty.....
cheers
Dec 04, 2016 | Vizio Televison & Video
Blue screen, no picture. What's wrong?
The board where the power button is located (same board for the other buttons too) is probably bad. It's all one board, which tells the power board to come on. If this happened after a power surge, and you're not using a surge protector, multiple boards can be bad. (You can't just plug these fragile TV and Blu-Ray players into the wall outlet. Eventually a surge will destroy them). Ps... A lot of people are suddenly making this same complaint with Vizio TV's.
Mar 03, 2016 | Vizio Televison & Video
For about a month when I press my vizio on switch the tv would click on the vizio emblem would light up,then it would immediately click off and the emblem would go dark...I would have to repeat this...
unplug the TV. Press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
More troubleshooting can be found at www.vizio.com
Apr 22, 2011 | Vizio L32 32 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
Loud pop and now Vizio 37 TV will not work
This sound like the power supply board went bad. You should check that. See if the fuse on the board is blown first.. You can get a "pulled" power supply board on the net if needed.
Mar 07, 2009 | Vizio L37 Television
Vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Jul 15, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Vizio E472VL 47 LCD HDTV - 1080p, 1920 x 1080, 5ms, 120Hz, 100000:1, V Logo
281 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
