Question about Denon AVR 3808Ci Receiver
Hey there,i have a avr3808, everything worked fine. Now i don't get any sound in tuner mode. tv,blu ray all work fine. I dont have sound in main zone, and no sound in any other zones in the house. Please help. All the wires are fine. If i put tuner mode to manual i hear static..
Can't match the frequency response of my speakers to my 3808.
Posted on Jul 18, 2009
  • 2,071 Answers
Your tuner is need to resolder all components parts joints ,that is the symptom of loose connection or cold solder.
Hope it may helps:
Regards:
VOTIT
Posted on Jun 15, 2009
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
No Sound!!!!
That is called a TV, DVD combo. You either need the 6 legged sound IC chip replaced or the tuner needs a resolder on a cold solder joint inside it. (i've done this a few times, with a large magnefying glass)
Oct 30, 2013 | Coby 19 Tft LCD Tv with Side Loading DVD
The speakers for my Bose 123 suddenly don't work for any source. It had worked well for years. Mute is off. What can I do?
It sounds to me like the Bose 123 is to blame not the speakers. I think you can test the speakers by connecting a 1.5 volt battery for a short while (few seconds) accross any of the speakers terminals. Disconected from the amp. If they are working it will go POP
If it's the Bose itself then the main amp inside has failed.
Jan 25, 2013 | Audio Players & Recorders
No video via hdmi from blu ray
Have you attempted swapping out the HDMI cable for a different one? I recently had a similar problem and I determined that the HDMI cable was faulty. Now everything works fine.
Jul 26, 2012 | Televison & Video
Internal DVD not playing
Ur DVD drive said reading erorr,making clicking souond right?Take the tv aparts,take some Q tips,dip it in with some rubbing alchahol,clean the DVD drive laser eye should solved ur problems.
Apr 17, 2010 | Toshiba 24-Inch Flat TV/DVD/VCR Combo w/...
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
When using an HDMI cable there is no sound
Unplug,replug the tv about an hour reset the audio back to factory setting.Should work if ur main tuner signal board is good.
Jan 16, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Hi! I have a Magnavox DVD recorder/VHS combo. I
alot of times when the video cord gets pinched it will go to black and white you just have to replace it if that dont work. then its one of the machines.
Nov 06, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The sound stopped working on my koss KS2503. Yesterday everything worked perfectly fine. Today there is no sound. Everything else seems to work. I checked all the connections and have had no success. Is...
unplugg your tuner from the AC wall outlet then check the setting on the tuner do not try to watch and listen to the tv only try to listen to the radio or a CD and select the right option on the tuner to do so. If you have sound on any of the functions....radio or CD/MP3 then the problem lies on the setting not correct for the TV/VCR/DVD mode.
Sep 12, 2009 | Koss KS2503 System
Denon AVR 3808Ci Receiver Logo
279 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
