Question about Standard Horizon Boating
Back light on monitor - Standard Horizon Boating
Once power on the monitor after 20 seconds power off how iam rectifed
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 30, 2014 | Samsung SyncMaster 920NW Monitor
My sa200 will not turn back on
Good luck.
Jul 22, 2014 | Samsung SyncMaster SA200 Series 19in LED...
It is 7x3cm big, and its like dark green with bright green lines. I can see underneath it my screen, but only if i look deep.
if you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Nov 08, 2012 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor comes on and goes right to a black screen like the power was turned off but the power light is still green.
hi,
You have to check the back light of your lcd monitor. All lcd screen have a back light to illuminate the pixels. you can conform is the back light is faulty or not by watching the lcd screen nearby. Watch can you see any image (negative image) on the screen. you have to look very closely. if you see any image on the screen then the back light or the back light inverter is faulty.
You have to check the back light inverter board. Normally in lcd monitors you can see three circuit boards. power supply, mother board, and the inverter board. If available then try to replace the inverter board. There are high voltage transformers in this board. There is a chance for its winding get short. You will not get the transformer in open market. Try for the inverter board .
ok
May 06, 2011 | LG Flatron L1511SK (Black) 15 in. Flat...
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
Monitor comes on and can see picture, but almost black screed have to look real close in order to see screen piture
Sounds like the back light on your monitor went out. All LCD monitors and TVs have a back light that is used to illuminate the pixels on the screen. This is how the "Brightness" setting on your monitor works. If this back light is burnt out, then it would be possible to faintly see the colors on the screen, but they would be nearly invisible as the light that was supposed to illuminate them is burnt out.
The solution to this problem would be to replace the back light on your monitor, but that is a very time consuming effort and you run the risk of it not working in the end anyway. I recommend purchasing a new monitor to save yourself some time and a major headache.
If you are still interested in repairing your monitor try going here for a guide on how you go about doing it. It may also be possible to find someone to repair it for you, but once again, it would be a lot easier to buy a different monitor in the long run.
Aug 06, 2009 | Computers & Internet
Flashing light nothing else
Doesn't sound like a virus. Sounds like a fuse or something else is out. A red light isn't good. If the monitor is ok you get an amber light. I would suggest this monitor is gone. Sorry.
Jul 20, 2009 | Envision EN9410 19" Flat Panel LCD Monitor
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Flat monitor is stuck in sleep mode
difficult to say what is sleep mode yellow light green ight blinking light pleas elaborate
May 10, 2008 | Computers & Internet
Monitor black out
try to adjust the setting of your video and refresh rate
Mar 12, 2008 | Videoseven V7 R19WPS 19" LCD Monitor
Boating Logo
Top Standard Horizon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
