Question about LG LDE3037ST 30" Freestanding Electric DoubOven Range with 5 Radiant Elements, 4.4 cu. ft. True Convection Lower Oven, 2.3 cu. ft. Upper Oven, Infrared Griand SeCleaning
Lg LDE3037ST DISPLAY BLANK
Display started flickering then went blank
  • 44 Answers
SOURCE: LG VX8600 SCREEN WENT BLANK, PLZ HELP!!!
m8 sounds like your screen is faulty or your ribbon has been damaged in some way.to fix it you will need to open it and have a look at the ribbon if there is any damage vissible no matter how small it means ur ribbon is gone an you need a new 1.it could also be your screen if there isnt any damage on the ribbon then it could be the screen.it could be a combination of both. word of caution: if you try to open it yourself you could damage the ribbon.you wont notice it but its very easy to do.so be carefull. but if you want an expert to do it for try these guys http://www.mobilephoneservicecentre.co.uk/ good luck
Posted on Jun 27, 2007
SOURCE: LG LS55 LAPTOP DISPLAY SCREEN BLANK/BLACK
I have no sound my laptop lg ls55 please help me
Posted on Nov 29, 2008
budmrtn
  • 11361 Answers
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 14, 2009
  • 458 Answers
SOURCE: 3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Posted on Dec 19, 2009
  • 14 Answers
SOURCE: phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Hplaserjet p3005dn blank display
Is it blank and no back light?
Either way the display might have went dead/bad. These printers are not that old. I would call HP support to have it repaired.
Apr 19, 2010 | HP LaserJet P3005n Printer
No signal on monitor
Do you have another monitor to test your computer? Looks like a surge went into the computer display and damaged the video card.
Sep 07, 2009 | XFX GeForce FX 5500 Graphic Card
My phone went coimpletly blank can i reset it
Dear,
u mean that phone doesnt show anything even the startup display and went completely black... so it can be the cause of strip that joints the LCD to the circuitry because in most cases of filp phone it happens alot... get it repaired....if the display doesnt see at all, the format or reset will not work...its an other case dear
regards,
hope it will fix the issue so dont forget to rate it..
Jul 06, 2009 | LG Vu CU920 Cellular Phone
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Computer display is blank
Suggest you contact store where you purchased item from, or contact repair agent, if you start messing with it , you will invalidate your guarantee.
Nov 30, 2008 | LG WM-2277HW Front Load Washer
Serious problem
Check WGA if it is correctlly put on and go to DISPLAY PROPERTIES - SETTINGS - ADVANCED -MONITOR
Oct 15, 2007 | LG Studioworks 700S 17" CRT Monitor
LG LDE3037ST 30" Freestanding Electric DoubOven Range with 5 Radiant Elements, 4.4 cu. ft. True Convection Lower Oven, 2.3 cu. ft. Upper Oven, Infrared Griand SeCleaning Logo
Top LG Home Experts
Donni Steen
Tom Chichester
Are you a LG Home Expert? Answer questions, earn points and help others
